Mate, that is soooo Cool, great idea....I want one for my GTST
How much do you charge ??
Thanks for the comments.I just thought my car needed that little something else to be able to show the car this coming year ( my last year with the car before emegrating to around the Adelaide area from Scotland ).
I made this for myself. Not to difficult to do.Cut the centre section from the plug cover, smooth the edges,cut a piece of clear acrylic to size, order graphics from Likwid Art and add to the acrylic then bond into place add 2 blue cold cathode tubes and wire them up and there you have it...
https://www.sau.com.au/forums/topic/153450-update-pics/#findComment-2855228
why did you decide to go cold cathode?? rather then an L.E.D type, looks frikn awesome either way?
but you've got my curiosity on this one?
Only went for cold cathodes as i had them lying around doing nothing.They are only held in place with some semi hardening silicon so is they get damaged/broken then 2 mins will replace them once the plug cover is off. I beleive the LED would have cast a harder/sharper light with more direction to it--i dont want the light being so and think the cathodes cast a smoother/softer style lighting.
https://www.sau.com.au/forums/topic/153450-update-pics/#findComment-2857510
i guess it depends on how many L.E.D's youd use, id probly suggest 2 either end.........this way it would be reasonably soft. but i like the idea either way man, looks fantastic and is pretty original, wish i had the time to do something similar, never would of thought about putting some sort of lighting in my rocker cover.
might have to think and try something different (thinking cap on......beer in hand) this may take a while
Edited by Nathan_G1
https://www.sau.com.au/forums/topic/153450-update-pics/#findComment-2858614
how will the light under the coil pack cover go with the heat generated in there?
but it looks great... its so shiny, i could have a shave in front of that thing!
Ran the car for about 20-25 mins yesterday to see how the lights and 3D graphics would hold out, glad to say all is fine at the moment. The cathode lighting is kept in place by semi hardening silicon so it can easily be removed if need be. Will keep an eye on the graphics to see if they have any problems...So alls good so far but needs a longer harder run to see how she goes.
https://www.sau.com.au/forums/topic/153450-update-pics/#findComment-2859318
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
