Mate, that is soooo Cool, great idea....I want one for my GTST
How much do you charge ??
Thanks for the comments.I just thought my car needed that little something else to be able to show the car this coming year ( my last year with the car before emegrating to around the Adelaide area from Scotland ).
I made this for myself. Not to difficult to do.Cut the centre section from the plug cover, smooth the edges,cut a piece of clear acrylic to size, order graphics from Likwid Art and add to the acrylic then bond into place add 2 blue cold cathode tubes and wire them up and there you have it...
https://www.sau.com.au/forums/topic/153450-update-pics/#findComment-2855228
why did you decide to go cold cathode?? rather then an L.E.D type, looks frikn awesome either way?
but you've got my curiosity on this one?
Only went for cold cathodes as i had them lying around doing nothing.They are only held in place with some semi hardening silicon so is they get damaged/broken then 2 mins will replace them once the plug cover is off. I beleive the LED would have cast a harder/sharper light with more direction to it--i dont want the light being so and think the cathodes cast a smoother/softer style lighting.
https://www.sau.com.au/forums/topic/153450-update-pics/#findComment-2857510
i guess it depends on how many L.E.D's youd use, id probly suggest 2 either end.........this way it would be reasonably soft. but i like the idea either way man, looks fantastic and is pretty original, wish i had the time to do something similar, never would of thought about putting some sort of lighting in my rocker cover.
might have to think and try something different (thinking cap on......beer in hand) this may take a while
Edited by Nathan_G1
https://www.sau.com.au/forums/topic/153450-update-pics/#findComment-2858614
how will the light under the coil pack cover go with the heat generated in there?
but it looks great... its so shiny, i could have a shave in front of that thing!
Ran the car for about 20-25 mins yesterday to see how the lights and 3D graphics would hold out, glad to say all is fine at the moment. The cathode lighting is kept in place by semi hardening silicon so it can easily be removed if need be. Will keep an eye on the graphics to see if they have any problems...So alls good so far but needs a longer harder run to see how she goes.
https://www.sau.com.au/forums/topic/153450-update-pics/#findComment-2859318
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
