  • Replies 74
Sorry guys,let me clarify.On a post on page 2 I said that I had a dyno run with no lid,that was with bonnet up.Obviously that would make a big difference in temps.But the run with 2kws less was with bonnet closed.So the setup really isn`t to bad.Three inch pipe from old cooler hole to underside of snorkel.Clamp both ends using pvc pipe connectors.Then cut small hole in front of lid facing headlight about 1'' by 3".Yes I know it isn`t perfect due to a little under bonnet temps but it does get me close to no lid at all.
Why dont u create the vent in the bonnet so it is designed that the air enters the bottom of the car and exits the vent. thats how its all supposed to work. you dont stick a vent over the pod. therefore rain wont be in issue unless u are driving 80km/h in reverse for it to be going into ur pod.
My brother has a cf bonnet on his Supra (TRD style) that has vents over where his pod sits and it comes with plastic inserts that you can stick in to block the vents off if it rains. You just need to remember to put them in! (he forgot once, bad move!)
  • 1 month later...
Exactly what I did but put a flexable tube from from old cooler hole in guard to underside of snorkel between the curve of the cooler pipe and the air box.To make up for lost intake width.
i just used the radiator air deflector with scoop to compensate
I was under the impression in vic that the epa laws state "must be a standard and un-modified air box" if you have a fmic that is...
but like dezz said if your car has a standard fmic then a pod is ok to have...
but as for the topic i do agree with the factors involved with a air box without a lid, it'll be the same concept as having a pod.. hot air from engine bay...
i'm in the process of having different intercooler pipes made to go around the air box guide.. (i wish i baught a intercooler that used the standard holes lol)
but you live and learn :)
  • 2 months later...
Hey EGA41T - I see your pipe that comes over the radiatorhas a nice bend back downwards after going over the radiator fan. Mine heads upwards and doesn't come back down - hitting the bonnet a little.
Because yours bends back down it means you didnt have to take quite as much out of your snorkel. Did your pipe come like that or did you get the pipe bent afterwards?
Cheers
- mine is a justjap kit..
Hey EGA41T - I see your pipe that comes over the radiator has a nice bend back downwards after going over the radiator fan. Mine heads upwards and doesn't come back down - hitting the bonnet a little.
Cheers
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
