"car is a a r32 gts-4 that has been converted to a gts-t"
I take it that means it is 2wd and all of the 4wd components have been removed. Hence it is 160 kgs or so lighter, all over the front wheels. That means the engine subframe, lower control arms and radius rods have also been changed to R32GTST parts.
If that is the case then you need R32GTST components
Rather than coil overs, try the Group Buy, it's a far superior solution
http://www.skylinesaustralia.com/forums/in...showtopic=85591
cheers
https://www.sau.com.au/forums/topic/153552-coilovers/#findComment-2856794
yep thats right, i didnt do the conversion myself i bought it like that, at the time i didnt relise that it was originally a gts4. so it still has the gts4 suspension, oh an your link doesnt work.
I have reloaded the link and it works for me. If it doesn't work for you this time have a look in the Group Buys section its about 5 or 6 from the top.
You have to talk to the guy who did the conversion. You need to know what he did about the front (engine) subframe, did he leave it GTS4 or change to a GTST one? Otherwise you are going to have all sorts of issues with camber and caster caused by the location of the subframe and the radius rods (they are also different between GTS4 ad GTST). Plus what uprights he used, GTS4 or GTST?
:pwned: cheers :O
https://www.sau.com.au/forums/topic/153552-coilovers/#findComment-2857111
the only problem is i have no history on the car what so ever, the car originally started out as a non-turbo auto gts-4, an now its a manual rear wheel drive turob(weird i know who ever did the conversion should of just bought a gts-t) but yes the converson has been done properly so the subframe has been changed an hicas has be removed.
https://www.sau.com.au/forums/topic/153552-coilovers/#findComment-2859759
