hey everyone.
R32 GTST 1990
Was driving home last night with the usual semi-enthusiastic driving we all like to do. Turned a corner and the car just didnt feel the same acceleration wise. Also going up hills in say 3rd or 4th it will rev to say 2K or 3K and just sorta not want to go past this. Out of first and second it will rev out ok but a lil bit slower then usual.
The stock turbo gauge indicates that it can get full pressure...so i dun think it's turbo
the car also sounds exactly how it should (perfect note) at idle.
such a wierd thing...i turn the corner and power is now only 2/3 of what it should be and up hills can only make it to a certain limit.
I have done my searches and most people seem to report power losses ABOVE a certain higher range (say 5K) mine seems to be just in general not that great a much power as before
I'm thinkin fuel pmup, or piping, or coil packs as per the suggestions in other threads
just wanna know if anyone experienced this problem and what was the resolution??
any help would be great!
https://www.sau.com.au/forums/topic/153558-r32-gtst-running-weaker/
fair enough guess i must admit...but....the clutch was put in like a yr n half ago so not likely.
i think it actually MAY have been bad bit of fuel and or sparkies gettin old...cos it was ok to drive today...very odd tho
hey i seem 2 have a problem similiar 2 yours
in second or third wen i flat foot it the car seems 2 jerk at times. feels like its struggling.
must add that it doesnt happen all the time.
its standard apart from cat back exhaust, pod and bov. Car seems fine otherwise.
Had feed back, and there suggesting it could be either:
-fuel pump
-engine coils
spark plugs
Hope that helps :)
hey mate
yeh i thought it could be one of those
there's no real problem at the moment hence i reckon its bad fuel or sparkies lil bit old
with ur car jerking i'd say could be fuel pump.
my mate recently changed his fuel pump in a 200sx and said it was jerking before he changed it.
Just a lil bit of feed back...i dont want to tell u to change anything cos i'm obv not the mechanic.
cheers
