hey guys i bought a ke70 of this forum about two months ago and cant afford it at the mo on holidays and have no cash and want to get my 1via painted.
here is a list at what was done when i brought it.
new engine with 60,000kms (from a grannys rite off)
new 4 speed gearbox.
new extreme clutch very tight.
fresh respray in maroon with black roof.
flared rear gaurds
no interior.
bucket seat.
oil temp, water temp and tacho gauges not connected.
all new springs
new brake pads
the alternator was rebulit
sports wheel.
brand new extractors.4-1
and 2.5inch exhaust.
since i have owned the car i have also done.
new bosch coil
new fan
new carby and timing done at madaz motor sport
purchase new bumper
new battery.
service.
rego'd for three months from today.
the car is in not bad shape few bits of rust here and there but not to bad.
it needs rims and tyres i have tried to find a set with rubber but couldnt. so the person thats buys this needs some rear tyres and rims and also a wheel alignment.
the interior can be sourced for a couple hundred if really needed.
i need this gone by the end of the week end so im open to offers.
was looking for 1200 with 3 months rego.
but make an offer.in s.a
cheers ben.
0416640060
http://www.nissansilvia.com/forums/index.p...st&id=69032
pm me with email for more pics
https://www.sau.com.au/forums/topic/153571-ke70/
  • 3 months later...
lol is this thing still gettin around.. me and a mate build it down in victa harbor.. and painted it up in a shed.. lol. dont no who told ya its a grannys motor, its out of one of our bash cars..was a sick car tho, just needs to be slamed.. has it still got the dodge struts in the front.?? might be keen for it back
https://www.sau.com.au/forums/topic/153571-ke70/#findComment-3113912
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
    • Excellent...maybe even instead of RB rebuild start with 6L LS and add boost for good measure!
    • This sounds do-able except space is a little tight were it's currently sitting. How many metres you reckon it would need to go?
