New guy...
Guest Skyline Fan 01
Hey everyone,
I'm new to this whole forum thing, so I've got no idea really what i'm doing. Guess i'm just tryin to find my way around.
One thing is i know basically next to nothing about cars. That is, the insides of them, like engine specs and all that. So, if anyone can give me a run-down of what all the fancy terms mean, then that'd be nice.
If any1 has any pointers 4 me about forums (this 1 in particular obviously) then it'd be greatly appreciated.
Also, I've got around 17-20k for my first car. Any suggestions?....Doesn't matter what. Doesn't have 2b a Skyline necessarlily.....but preferably, of course.
Anyway, thanks heaps.
https://www.sau.com.au/forums/topic/15359-new-guy/
  • Replies 43
if u arent really concerned about what car u get then you should just consider the economic and use factor, will u use it everyday, how far will u travel etc. Skylines do tend to be a bit heavy on the ocket for petrol, specially if u just lurrrve pushing that accelarator. i suggest sum front wheel drive toy, good fun, handbrakies are good fun too hehe
https://www.sau.com.au/forums/topic/15359-new-guy/#findComment-314624
ok cool......thanks for that everyone....that kinda gets me started in the right direction. At least i've got some idea of what to look for now.
I'm still not sure how much i'll have to spend, cause i'll have to wait as the olds are tradin' in mums 2001(?) pulsar +, so i'll have to just see, but that's the rough amount.....
And i'll definately be asking about what some terms mean, cause my friends know their car jargon, but like i said, i've got no idea, so thanks heaps for that as well.
Also, what's the easiest way to tell the difference between the R33 and R34 Skylines?
https://www.sau.com.au/forums/topic/15359-new-guy/#findComment-315111
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
