New guy...
Guest Skyline Fan 01
Hey everyone,
I'm new to this whole forum thing, so I've got no idea really what i'm doing. Guess i'm just tryin to find my way around.
One thing is i know basically next to nothing about cars. That is, the insides of them, like engine specs and all that. So, if anyone can give me a run-down of what all the fancy terms mean, then that'd be nice.
If any1 has any pointers 4 me about forums (this 1 in particular obviously) then it'd be greatly appreciated.
Also, I've got around 17-20k for my first car. Any suggestions?....Doesn't matter what. Doesn't have 2b a Skyline necessarlily.....but preferably, of course.
Anyway, thanks heaps.
https://www.sau.com.au/forums/topic/15359-new-guy/
  • Replies 43
if u arent really concerned about what car u get then you should just consider the economic and use factor, will u use it everyday, how far will u travel etc. Skylines do tend to be a bit heavy on the ocket for petrol, specially if u just lurrrve pushing that accelarator. i suggest sum front wheel drive toy, good fun, handbrakies are good fun too hehe
https://www.sau.com.au/forums/topic/15359-new-guy/#findComment-314624
ok cool......thanks for that everyone....that kinda gets me started in the right direction. At least i've got some idea of what to look for now.
I'm still not sure how much i'll have to spend, cause i'll have to wait as the olds are tradin' in mums 2001(?) pulsar +, so i'll have to just see, but that's the rough amount.....
And i'll definately be asking about what some terms mean, cause my friends know their car jargon, but like i said, i've got no idea, so thanks heaps for that as well.
Also, what's the easiest way to tell the difference between the R33 and R34 Skylines?
https://www.sau.com.au/forums/topic/15359-new-guy/#findComment-315111
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
