Dropped by my local Jaycar store and had a look in their catalouge and found a kit which will solve all our problems :pwned:
Car Air Conditioner Controller Kit
This kit stops the air conditioner in your car from taking engine power under acceleration. It will allow the compressor to run with low throttle even when the cabin temperature setting has been reached and will automatically switch the compressor off at idle. it also features an override switch and an LED function indicator. Kit supplied with PCB with overla and all electronic components.
Recommended box UB3 HB-6013
$39.95
Cat. KC-5437
Someone buy it and install it :O
- Patrick
https://www.sau.com.au/forums/topic/153594-no-more-lag-with-air-conditioner-on/
Not an entirely bad idea...
I think i'd rather have mine turn off when i'm on throttle but below 1500rpm. Every time it's on and I take off from the lights there is so much horrible lag that you really need to ride the clutch a bit to be smooth. On at idle though... it'd suck sitting in traffic sweating to death!
As far as i knew the standard computer turns it off on WOT anyway, atleast the Z32s do, guessing the RB powered cars would be the same.
If you need to turn it off, run more boost because your car musn't have any balls to begin with.
Solution: I perscribe a case of harden the fark up and get rid of your AC totally, followed by using your power window button and harness the wonderful noew power of wind to cool you down :(
werd!
i sometimes use my A/C and it doesnt give me any lag.. ?
ive never had a problem with my A/C and lag. As for you non-air con guys, ill gladly take a few camp jokes and continue to sit in comfort on those 30+ days without sweating into my expensively retrimmed leather pews, whilst i have a chuckle at all the guys with the windows down trying to look like they arent hot, obvious to me that if they had a functional air-con, they would use it! :O
Part of the reason why i own a skyline is that it does everything, comfort on hot days included. Getting rid of the aircon on purpose, to me is like ditching the power steering! why would you?
Edited by SLY33
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
