back to topic..
according to the title, I will say TD06-2og will be easy to drive around, and comes with some very good power, and if you can invest some $$ on cam gears / cams then it will be perfect..and this is back up by riding experience of Buster's car. thanks.
  • Replies 90
I will ask buster to answer this questionin in detail..
But I will say what I saw..
Td06-20g 10cm sqr, trust manifold, front pipe,3 " exhaust system, external wastegate, Trust cooler, EVC, chipped R33 ECU..
from what can see at passenger side..spool around 3100...hard at 4000 (up) till red line...lag was there, but not what I expect..power come smoothly..
He sold the car....and the car now is in autostyle sydney..but both of us will have something similar come up soon..will keep you post.
mmm... on the other turbo's thing...
(don't shoot me i'm no expert)
I think i still have the stock t04E that came on GTS-R's.
Now my car has an RB25 though and it hits full bosst around 4300 and makes boost from around 3500 or something near that.
It produces 190rwkw @6600 on 9.5psi
at 4500 it has 120rwkw and 5500 it has around 160rwkw.
To drive it's nice, and between gears i don't drop 1,500 rpm (maybe i have modded box, no idea though), so i can stay on full boost in every gear.
I know that a t04 is like super old technology and stuff but you can mix/match the exhaust and front housings/wheels i think ??
And from what i've heard they aren't all that expensive. Like approx $1500-$2000 ?
just a thought that's open to discussion as i wouldn't mind learning some stuff :D
Usually on the compressor or front housing, and the exhaust or turbine housing.
Turbine housing is pretty important to determining when a turbo will come on boost, the smaller the housing, the sooner the boost comes on - the trade off being you wont have as much top end. The sort of power you are making is easily acheivable with a stock turbo, but they tend to come on boost just over 2K with a good exhaust setup.
If I had to guess, I would say that your exhaust AR ratio is a little on the large side.
EDIT: also the T04E isnt a small turbo for a 2.5
NFI!
i've got this extractor cover/shield thing. I'll get it off in the next day or two and have a look.
I do know though that the mouth (where it sucks air in) is reasonably big.
mmm, i've seen cars achieve what i am with the stock turbo, but they are all running more than 9psi of boost ?!?
Yes, true, but think about this: my car runs 12.5psi has a stock turbo and makes boost from 2000rpm full boost by 2500 and 203 rwkw peak,
You have 120rwkw at 4500,
I make 120rwkw at about 3300rpm, by 4500 I am making 165
rwkw. By the time your engine is making 160kw, mine has made 190.
It takes you nearly 1000 rpm to make your 9.5psi, I can get 12psi in about half that and it starts 1500 rpm earlier.
Which setup, if both were fitted to the same car do you think would make a quicker car?
Now, if you could make 12.5psi by 3000rpm...
yep Phil you hit the nail on the head all I can see you missed is the 550 inj, Bosch fuel pump and Z32 afm
It did start to spool in the low 3000rpm's and had full 1.1 bar by 4000rpm the boost did come on pretty harshly hahaha all in all I think the set up is great when you look at the cost of one of these turbo's and how cheap they are to have rebuilt
Hi Guys, I posted this before....
Graph peaks at around 308 rwkw at 196 kph which would be 7,250 rpm allowing for 27 kph per thousand RPM. That means at 108 kph (around 4,000 rpm) it has 93 rwkw
So if you changed gear at 7,000 rpm in first the engine would have 300 rwkw and would drop to 4,000 rpm in second where it had 93 rwkw. It would then struggle to accelerate the car until it got to around 5,000 rpm when the power jumps to 180 rwkw. This would indicate not very much boost under 5,000 rpm.
Simple table follows; as shown on the TD06 dyno graph on page 1
At 7,000 rpm it has 300 rwkw
At 6,000 rpm it has 250 rwkw
At 5,000 rpm it has 195 rwkw
At 4,000 rpm it has 93 rwkw
That's an average of 210 rwkw.
This would make, firstly a fairly slow accelerating car through the gears as it has a relatively low average amount of power (210 rwkw) compared to its maximum. Secondly this would make it very difficult to drive as it would be constantly moving from over 300 rwkw to under 200 rwkw with only a 1,500 rpm drop in revs.
I would say that the turbo is too big and the car would be faster with a smaller turbo, say one with a 260 rwkw maximum. Power table like this;
At 7,000 rpm it has 260 rwkw
At 6,000 rpm it has 240 rwkw
At 5,000 rpm it has 200 rwkw
At 4,000 rpm it has 170 rwkw
That's an average of 220 rwkw.
Higher average therefore faster accelerating and it would only drop from 260 rwkw to around 220 rwkw in the same 1,500 rpm bracket. Result = much easier to drive.
Hope that made sense.
*Now, read it, and stop talking about TD06's unless you all own a Mitsubishi Canter*
Sorry, that was way too harsh....had the 5am blues....rally didn't mean to say that like that...I meant to say
"now, stop talking about it
unless you own a Mitsubishi canter....."
In that i beleieve everything had been talked about here, and all the numbers have been shown... not that they are crap turbos so don't talk about them...i did not mean that
I honestly have no doubts that the TD06 could be a very effective turbo. I personally believe that running one on a 2.5 litre engine is not the best option. On a 3litre + engine i believe that could be very good, and would spool up 25% earlier. I have seen one on a diesel Hilux that was VERY interesting
I'm sorry if that sounded like me telling you you picked the wrong turbo, or that you are all worong, i really didn't mean that. I have personally never driven a car with a TD06..or for that matter any Trust turbos. I have driven a toyota hilux with one....that was scary. But the numbers coming out of the dyno graphs all seem to say the same thing, and spool up, at the bet off an RB25 was 4,000 rpm.... And i believe that does not add up to a very streetable turbo. But i could be wrong
Son of Sydneykid - Amended by Son of Sydneykid
..................................quote......................................
Hi, SydneyKid..thanks for the replied (not the ....quote.....part), and be honestly I do learn from it..but Were the fact and theory are brothers? Were they sometime back up each other and sometime don't due to some reason? I don't drive a canter, just what I saw is a bit different then theory..please don't take it as offense (I know you don't...hahaha..thanks.)
If there is any chance, we do love to offer you a drive..and maybe you can help us to find out why?..thaks
If I was to consider either a rework of my turbo or a garett combo what in your experience gives the best performance. Mick from Subzero now works were I take my car to so he says an exhaust manifold helps alot plus you know his plenums. For interest to back this up he is doing a standard turbo with exhaust manifold. Its on a friends car so should be interesting.
I would like to see 250rwkw for wank factor plus I believe this is a reasonable level to get to before needing injectors and maybe other internal mods. I have all else required.
So I could look at a Garett 3040 or a 3035. I would prefer to keep my origonal turbo however could have that reworked. End of the day though these all seem to pan out to the same cost.
Thanks
Hi Grepin
250rwkw is not a whole lot really. this is easily achievable with the hi flow, for a fraction of the cost... it simply bolts straight back onto the original exhaust manifold... very simple. you do not need such a large turbo for these figures. It is far simple and far more cost effective to simply get a Hi Flow job done on the existing turbo. Save the cash you save from not buying a new turbo and use it elsewhere on the car.
Son of Sydneykid
hey rob
it isn't the most effecient manifold, but for the 250rwkw, its sufficient... It is not an equal lenth manifold.... but its not worth spending the cash on another unless you are going way further than 250rwkw...In my opinion...but i will ask the old man
Son of Sydneykid
I guess I should have stated that to get 250rwkw that the standard manifold will do. However would a nicely designed manifold make it work all the better. I guess the proof will be in the car that is keeping the stock turbo however getting a manifold. Certainly a different way of going about things. Consider if I havent got it wrong it may be possible to get more top end out of a set up manifold. Like how it can be said that a larger turbo can be brought on boost earlier by a specifically designed manifold.
Sydneykid, so you havent had much experience with Garett turbos like 3040 etc. Cost wise considering Sacrifice $500 worth of turbo for a $2400 (GCG price) rebuild is more expensive than buying a Garett turbo (from $2300). Given the fact that I want to keep all my stock parts I would prefer to keep my turbo. The only reason to rebuild it is if it would be far superior than a garett turbo.
Cheers.
I hope I finally get it right when I do comit to something. Its even more frustrating when you have the money but no idea what to do.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
