Quick Intro
Scadtional
 Share
Hey people,
I’ve just moved to Brisbane from up north, new job (network engineer) in Murarrie and a new car, Skyline R33 GST-T (5th car). I got it from gold star autos (hopefully it’s not dodgy) Anyways, I’m a pretty keen driver, when I get bored, I go driving around randomly. I’m still getting use to it, since my last car was a Hilux surf.
At the moment my R33 is pretty stock, apparently it has some GTR options, 17inch wheels and a exhaust that doesn’t wake the neighbors.
I have done some researching and I think the first thing ill do to it is throw on a FMIC. BUT, there are 100’s of crazy named brands out there, so I have no idea on which kit to get.
Well, I’m keen to go for a cruise any time. So pm me if u are bored. I live in red hill at the moment, moving to kangaroo point next weekend.
Kev
Welcome to SAU
Come along to a few Tuesday night dinners and meet the crew, disscussion generaly revolves around modifing skylines or discussions of a sexual manner...
Some times both... :P
You will find all the info about dinners in the event section here in the Queensland area of the forum...
Hi mate welcome, probly see you around cruising.
Good luck with the future mods.
I hope you have a lock up garage for the 33, as they are very popular with the criminal element around Brisbane and Gold coast.
nice grille!!!!!!!!! is that a 95 model?, i can justg see the series 1.5/2 wing on the back. if its a cat back `exaust, get a 3" dump pipe and down pipe, you will not regret it.. :( and front mount if you are running more boost :)
welcome bud.
i like the colour what would u say it is.
gun metal or pewter?
just jap has FMIC for 345 check sponsors. and ill fit it for u for a bit more :(
and i like ur grill far better than the standard 3line GTST S1 grill.
hey, nice car for sale... i would not mind those mods hey.. half of me would like to see if you would trade for my 33gtst.. but 32 interior doesent like me.. any vids of your car?
i have a nismo style grill for sale if anyone wants it, was brought from japan brand new, i used it for 2 months, and still in mint condition... black fibre glass with a red S in the middle, only for a series 2 only..$80? any one
That is an awesome grill! I tried to find one for my 33 but had to settle for a GTR grill instead. Oh and welcome
Mine has the same with NISMO in it. Came with it from japan so I dont know where one would track one down. It wasnt painted though when I got it, just matt black plastic.
I think it looks a load better than the standard 3 bar one anyway,
Edited by Turbo Tim
 Share
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
