What if I don't want to unplug the battery lead?
it's far easier than shorting out your wiring harness, causing a fire, and watching your pride and joy burn to the ground.
ok maybe i'm exaggerating, but seriously.. taking the battery terminal off is by far the easiest way.
I personally do not feel comfortable wiht the shorting the pin method, because I have not read that in any of my nissan manuals (someone correct me if I'm wrong, because the indexing of the manuals is very bad).
Disconnecting the battery seems to work sometimes if it's disconnected for a long period of time but I hate losing my radio stations.
Nowadays, I just use my laptop to do it. I can reset the ecu and clear the self learn.
correct me if i'm wrong....and i know this is a long standing debate...but resetting the ecu does sweet fuuck all....apart from clearing your error codes.
the ecu learns everytime the car is switch back on. it doesnt have the capacity for long term memory of the parameters you're hoping to 're-learn'.
ive been told this by tuners, and other ppl who have technical knowledge of ecu's. and it makes total sense.
why would the ecu restrict its ability to adapt to new situations, and only work at its best when ppl with 'supposedly' inside information decide to disconnect their battery.
ive tried it, made no difference at all.
It made a difference to my car..
How?
Well it doesnt run as rich anymore..
It doesnt smell as much of exhaust fumes due to the car not running as rich..
The car actually felt a lot better once it was reset..
For me it worked. Gettin more milage.
Remember to dc the alarm.. Otherwise you gonna go deaf like me lol when you dc the battery..
And yup your headunit settings will be reset.
I thought the wires to be shorted were on the ecu, not the fuse box.
Resetting mine didn't do anything either.. Wouldn't the ecu just be set up to react to current environments and not remember the way the weather and your driving has been for the last 6 months.. That seem's the logical way to set it up to me :(
BTW, can I use nissan data scan to reset the ecu?
Reading here: http://202.43.226.57/
Last item on point 4 "clear self learn", that is the one isn't it?
(maybe I'll build one and have more fun with the car :stupid: )
i thought that the ecu would adjust itself to new mods quicker if you clear it, as it would adjust in large increments when first trying to learn, then smaller and smaller as it gets closer to optimum. when you change something tho, it has to use these tiny increments to get to the new optimum running...
so reset it and it starts off big again
thats my lil story :(
I don't know about data scan. Its not my favourite consult software. My software can result the ecu itself as well as the self learn.
What are you using dude? At the moment I'm using ECU Talk, but I'm interested in whatever does the best job.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
