What if I don't want to unplug the battery lead?
it's far easier than shorting out your wiring harness, causing a fire, and watching your pride and joy burn to the ground.
ok maybe i'm exaggerating, but seriously.. taking the battery terminal off is by far the easiest way.
I personally do not feel comfortable wiht the shorting the pin method, because I have not read that in any of my nissan manuals (someone correct me if I'm wrong, because the indexing of the manuals is very bad).
Disconnecting the battery seems to work sometimes if it's disconnected for a long period of time but I hate losing my radio stations.
Nowadays, I just use my laptop to do it. I can reset the ecu and clear the self learn.
correct me if i'm wrong....and i know this is a long standing debate...but resetting the ecu does sweet fuuck all....apart from clearing your error codes.
the ecu learns everytime the car is switch back on. it doesnt have the capacity for long term memory of the parameters you're hoping to 're-learn'.
ive been told this by tuners, and other ppl who have technical knowledge of ecu's. and it makes total sense.
why would the ecu restrict its ability to adapt to new situations, and only work at its best when ppl with 'supposedly' inside information decide to disconnect their battery.
ive tried it, made no difference at all.
It made a difference to my car..
How?
Well it doesnt run as rich anymore..
It doesnt smell as much of exhaust fumes due to the car not running as rich..
The car actually felt a lot better once it was reset..
For me it worked. Gettin more milage.
Remember to dc the alarm.. Otherwise you gonna go deaf like me lol when you dc the battery..
And yup your headunit settings will be reset.
I thought the wires to be shorted were on the ecu, not the fuse box.
Resetting mine didn't do anything either.. Wouldn't the ecu just be set up to react to current environments and not remember the way the weather and your driving has been for the last 6 months.. That seem's the logical way to set it up to me :(
BTW, can I use nissan data scan to reset the ecu?
Reading here: http://202.43.226.57/
Last item on point 4 "clear self learn", that is the one isn't it?
(maybe I'll build one and have more fun with the car :stupid: )
i thought that the ecu would adjust itself to new mods quicker if you clear it, as it would adjust in large increments when first trying to learn, then smaller and smaller as it gets closer to optimum. when you change something tho, it has to use these tiny increments to get to the new optimum running...
so reset it and it starts off big again
thats my lil story :(
I don't know about data scan. Its not my favourite consult software. My software can result the ecu itself as well as the self learn.
What are you using dude? At the moment I'm using ECU Talk, but I'm interested in whatever does the best job.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
