Is There Any Links To Find Out What 0-400 Times Are
yeah i know i havent got it back yet it will be put on the dyno this week i still gotta get used to mit before i take it down but im just curious about what it should sort of run
With slicks and a good launch off the line low 12's should be possible
you reckon?
i was hoping maybe just in the 12's id be happy with that even a real low 13 id be happy
its only the r32 gts-t
might need to change clutch cause its stil stock it will probly slip
stock clutch with 240rwkw = big risk. You better change it before you go to caulder otherwise you will be towing it home!
you reckon?
well im comparing your car to an a guy i spoke to at WSID last time i raced, he had a S15 with 230kw at the wheels, using semi slicks, and running 12.3
you'll need a good clutch to get off the line though :)
yeah cool i was gonna get one anyway. i will wear it out a bit first tho
wel that sounds promising
id be stoked with that only thing is my car will be laggy cause its a big turbo for the little rb20
so im not sure if it will pull a low 12 it wont come on boost till a bit later than most gts-t's but when its up there it should be nice
