Is There Any Links To Find Out What 0-400 Times Are
yeah i know i havent got it back yet it will be put on the dyno this week i still gotta get used to mit before i take it down but im just curious about what it should sort of run
With slicks and a good launch off the line low 12's should be possible
you reckon?
i was hoping maybe just in the 12's id be happy with that even a real low 13 id be happy
its only the r32 gts-t
might need to change clutch cause its stil stock it will probly slip
stock clutch with 240rwkw = big risk. You better change it before you go to caulder otherwise you will be towing it home!
you reckon?
well im comparing your car to an a guy i spoke to at WSID last time i raced, he had a S15 with 230kw at the wheels, using semi slicks, and running 12.3
you'll need a good clutch to get off the line though :)
yeah cool i was gonna get one anyway. i will wear it out a bit first tho
wel that sounds promising
id be stoked with that only thing is my car will be laggy cause its a big turbo for the little rb20
so im not sure if it will pull a low 12 it wont come on boost till a bit later than most gts-t's but when its up there it should be nice
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
