hi.
have any of you guys had any issues with the jaycar responce 4x100 digital full range car amp?
ive been thru 2 so far!!!! the first one just stopped working.
and the second oner doesnt work at all!!
ive no probs with my class d sub amp but.
just curiouse as its only a 4ohm load and all hooked up properly....
https://www.sau.com.au/forums/topic/153669-jaycar-responce-amp/
  T04GTR said:
hi.
I had an internal earth issue with mine, took it back and never had a problem with the next one.
I only used it for about 6 weeks and i sold it :happy:
Did you do the install or was a professional install???
I only used it for about 6 weeks and i sold it :(
sounds likethe red light of death to me. short the speaker wires for a second and it wont go ever again.
nup where alll done proper. i did it myself. i am a qualified mechanic. and know what im doing.
the first one just stopped all together. to the point where the protect light came on with just the power ooked up. nothing else.
the second one. wich is clearly a reapaird one cos one of the swithches is busted off.
no warning lights just the green one. and all you get is a loud crack threw the speakers :s
first one did an output stage- quite common.
second could be anything. which switch?
(actually show me.)
Qualified mechanics work on my engine, noone qualified them to work on my car audio equipment :D.
Hahahahahah only joking dude. Are both amps running from the same power wire and fuse? If it was me i would first check whether you got a good power and earth on the amp and also that the remote wire is all good.
Its strange your first amp stopped working the second wont power up. If you got separate power cables for your 4 channel and class D i would check the fuse under the bonnet for the 4 channel.
George
Adelaide Pro Sound
Ive got the previous model 400watt amp... its blue... ive had it powering 2 15's and its powering 2 12's right now cause my 3000watt amp is in the shop... ive never blown it, never 'over'heated (though i do over work it so its gonna get hot) the ONLY problem i ever had with it was one of the threads wore out cause i used it as a back up all the time... that was replaced for free...
dunno about their new range...
  Dav said:
i got one of the old school blue ones too and its still goin, had it for about 2yrs now maybe 3.
jaycars primary focus is not amps...
i dont go for companies that dont excell in the areas i am interested in ( obviously)
do some more research on the net and get a few pointers from different peeps.
I personally like soundstream gear.. that stuff makes me happy in the pants
  • 6 months later...
I have had a D-CLASS Reponse amp and had no problem, ran it pretty hard too.
My friend also has one running 3 x ALPINE 12" subs off his one and been running fine, also has a 4x100RMS one running his ALPINE splits, front and back with no issues.
Jaycar's amps are supposed to be very good quality and very good value for money.
Maybe you have just had bad luck.. twice lol
Anyways, hope it all works out.
Thanks,
Abu
also.. im not that clued up on this sort of thing but.. my head unit only puts out 2.2v preout. and to get any sort of decant volume i have to have the gain on the amps turned up the whole way. ie:down to the 500mv scale.
now is this a bad idea for sound quality, is this likly to make the amp clip more? will i be able to get more volume and better sound out of a propper headunit that puts out say 4v preout? (i dont use the headunit amp)
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
