You guys have to start realizing bodykits dont come as a finished product.
Why are you guys trying to fit your own kits when you cant even fix a simple fiberglass crack ?
Stop blaming the sellers and when you get a kit pay for the kit and installation. Theres a reason why you get fiberglassers and bodykit installers so to speak.
While im at it, dont buy copies if you arnt prepared to do work to make them fit propertly. Go buy gen's your looking at 800 each for front and rear bars and 800 for a pair of skirts.
silent, I know that you know what you're talking about, and i'm not having a go at you personally, but this is what I believe.
The bodykit shop that I have forgotten the name of. Is it carhate or something similar like that charge about $14-1500 for a kit.
Someone else like gforce body kits will sell a full kit for $5-600.
In terms of fitment, I have never fitted a gforce kit, but I have a friend who has one on his car. No work was done to it, just sand, highfill, spray and bolt.
Of course, I understand that fibreglass copies are not perfect. What i'm saying, is that his bodykit is quite acceptable. Say if a genuine bomex/vertex/veilside etc plastic bumper is called 100%, his was probably an 80-85%. That is, you might see a little bit of ripple here and there, little bit sticking out here etc, but generally it was very good.
for 3 times the price i'd expect their things to be better, but to be honest, I have been pretty dissapointed with botht the quality of the product, as well as the way they handle issues wiht their product. Their answer is always let my people fit it. If the fit is shit, it's shit. Doesn't matter how you maneuver it and bolt it, it won't fit well. For the kit that i'm talking about, it needed reglassing of certain bits, etc etc.
The smash repairer was looking for another 1500 on top of that to make it good. Note, that is not painting, that is just the fibre work. The car was going to be sprayed anyways. Also, the 1500 was not to make it perfect. He wanted 5k.
So suddenly this bodykit ends up costing almost as much as a genuine abs one, but it's still not abs
    • This sounds like a perfect excuse to install a Haltech R3.
    • I do believe from context he is talking about a S0/S1 R33 RB25 with associated ECU and Wiring for that, and a manual gearbox into a R34 N/A Auto. I don't have the knowledge of all the pinouts and such but my gut feeling from doing my own conversion is to use as much of the R33 stuff that you can. The "car" wiring is quite seperate from the "Engine" wiring when all things are considered. The only things to truly consider 99% of the time is the cluster, reverse lights and potentially disabling the 'not in P/N' immobilizer circuit.
    • A realistic expectattion of how long it has to last also comes down to.... when do you think you will be banned from registering and driving old petrol powered shitters? It's 27 years since that thing was built. It probably rusted out 15 years ago. It was probably repaired and looked OK for another 10. If you do a similarish bodge job now, or perhaps slightly better with some actual rust conversion and glassing, then.... get another 10-15 years out of it, after which you'll only be permitted by the CCP to drive electric cars manufactured in their Shenzen zone anyway.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
