Hi guys,
The brakes on my R32 GT-R have always been crap. The R33 GT-R Brembo upgrade is slightly better but they just don't deliver that punch that I'm looking for.
I've taken the plunge and bought 6 pot AP fronts and 4 pot AP rears (full kit with rotora, brackets, fluid etc.).
What I need to know id what else do I need? The kit comes complete with everything I need to get them onto the car but do I also need to get a stronger/larger/upgraded booster? And I am very curious about a brake bias adjuster for the cabin too. Any advice on that (what brand, where from?) would be greatly appreciated. Thanks in advance.
Hi guys,
Justin, I don't think you need a brake bias controller, that brake package you've bought should have the right balance...
Have been wondering this myself does the booster need to be modded to run this kinda upgrade what about r33 brembos did u still run the same booster from the 32 or an r33 one? Do u wanna sell the brembos once u get the ap's on there, hint hint, might know someone who is interested.
i run 4 pot aps on the rear of mine 330mm
and f40 brembos on the front with 355mmon the front.
at just under 220km/h at wakfield after the kink it pulls up dead straight.
the fronts still get a much bigger work out. mand the rears just dont ware out lol.
i think youl be fine.
If you want brake bias adjustment you need a whole heap of other gear, brake balance bar/second master cylinder etc etc....way too much trouble.
If you find the rears are locking too early just put some less aggresive pads in there...but it sound like the balance should be OK anyway.
Out of interest, what does a set of 6 spot AP brakes retail for? more than the just jap 8 spots with 355mm rotors?
the main thing is that look look after the ol' beer baron with your old crappy, useless 33 GTR gear! I'll take it off your hands as a favour cause that's the kind of guy I am. :devil:
I think the kit you have sounds like it should be right as you are upgrading front and rear together.
I just put Porsche 6 pot's on the front of my car, and I think i need a bigger master cylinder, as the pedle is heap's longer now. So you might need to consider that.
Shouldn't do. AP know their stuff & don't go too large on piston area. Even the 6 pot CP5555 only list at 50.1cm2.
Edited by djr81
Hi guys,
Just to add another me too response, I run 6 pot CSC's on the front and 2 pots on the rear and the car pulls up straight. The CSC's are pretty much an AP copy.
I have been running Pagid Blacks on the front and Hawk HPS on the rear with no problems.
You have a nice package there.
Regards
Andrew
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
