as the title says i need a L20ET ecu pinout and wiring diagram asap i just need it too see if i can keep my L24E loom and just change the plug to a l20et one to suit the l20et ecu and then just add the extra wires needed
Your going to have a problem with this request, as we never saw L20et wiring diagrams or service manuals in Oz.
I have 280ZX Turbo manuals and I think they are almost identical in motor wiring. I can copy these if you wish but your going to have to decipher the links between MR30 & S130 yourself.
Cheers, D
Cheers, D
yea that would be great i supose its better than nothing and at this stage it looks like i may use a G-reddy Emanage with the L24E ecu and afm to run the show.
Im also going to the local dyno place to have a chat to them about what sensors and shit they think i need eg vaccum controller ect ect or whether they think i colud get away without one and also to get that ecu checked out.
i also had a thourght that maybe the L20ET manual and auto ecu's are different and one has three plugs and the other just one but thats just a thourght.
After i have been to the dyno place that should give me a bit more of an idear what i can and cant do.
http://forums.hybridz.org/showthread.php?t...;highlight=safc
Just found this that might help everyone.
http://www.autozone.com/servlet/UiBroker?F...23d801d1d80.jsp
This link should give you all the Z - ZX turbo & non turbo schematics you will ever need.
Cheers, D
  • 1 month later...
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
