Mr GTST,
17k might get you a non-tubo auto.
there you go. $17,000 camry that costs as much as a ferrarri to ensure. wikkid stix.
jmp,
got to Prestige Motorsports (google) and have a look at their recent stock lists. you can then pretty much add between 3 and 5 grand to the costs quoted there for something landed in Aus.
https://www.sau.com.au/forums/topic/15370-price/#findComment-314165
15 months ago I imported my r33 it cost me $17400 with alarm system on the road complete. It was a grade 4 vehcile inside and out, now the outside has a couple of pin dents and small scrapes thanks to australian carpark tosser's, but I'd said I paid a pretty high price for a dead stock vehicle, but it was in excellent condition for a 9 year old car.
https://www.sau.com.au/forums/topic/15370-price/#findComment-314192
approx $16k for an r32 gtst.
with basic lil mods.
they still dont seem to be THAT common in perth in comparison to places like Qld - so i think the prices are around $2k - $3k more here....just what ive noticed.
Well i picked mine up for $16k with exhaust, bleed, suspension, wheels and 85,000kms from a private seller
but if you can afford it..consider an 89 stock gtr...around 20k isnt bad for one
https://www.sau.com.au/forums/topic/15370-price/#findComment-314365
If you're only able to spend $20k on a car, are you going to be able to afford to maintatain a GTR?
I was thinking about this last night. Its an older car, EVERYTHING is rarer than the gtst and in most cases you've got to buy two of everthing....
I reckon there's gonna be a lot of 89 GTRs for sale domestically (private) because people just can't afford to own them.
Originally posted by RB20LagWagon
R32 should be able to be picked up for 16k for a nice example, they are not that much cheaper then r33s because 1 they are a better car and 2 the are more rare
ouch!
:D
https://www.sau.com.au/forums/topic/15370-price/#findComment-315817
The older the car the more likely it'll need some work done to it when you buy it. This can quickly negate the excellent deal you got on it in the first place. Either way if you buy a 89 GTR and you get a good one, then you're likely to pay top yen for it or you get one that needs some work and pay less yen but need to spend a few extra thousand fixing it up when it gets here. I'd still be budgeting $25-$30k for a r32 GTR either way. Face it, most of us are fastidious when it comes to our cars, no point bring in a 89GTR all banged up to save a few thousand if you arnt going to fix it up and make it look and drive nice. Though if anyone brings in a 89 GTR I'd love a look at it to see what its like :D
https://www.sau.com.au/forums/topic/15370-price/#findComment-315839
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
