Hey guys.
I searched hard and found a lot of people who were interested in the Greddy Pulley Kit (standard direct swap sizes) as well as a lighter, carbon tailshaft but no reviews at all. A hell of a lot of speculation and physics lessons were found, but no one actually left any real reviews.
I've linked up the parts in question below. Would appreciate your comments, experiences, opinions. I'm sure some of you out there would be keen on these items as well.
GREDDY WATER PUMP, ALT AND POWER STEERING PULLEYS MADE FROM DURALUMIN (A2017) ANNODISED BLUE FOR R32, 33,34 GTR. LESS THAN HALF THE WEIGHT OF FACTORY STEEL ONES FOR IMPROVED THROTTLE RESPONSE.
UAS ONE PIECE TAIL SHAFT FOR NISSAN SKYLINE GTR. LESS DRIVE TRAIN POWER LOSS, MORE RESPONSIVE - LESS LAG.
WEIGHS ONLY 9KG COMPARED TO FACTORY ITEM AT 14.5 KG
SUITABLE FOR R32 AND R33 GTR
https://www.sau.com.au/forums/topic/153711-lighter-pulley-kit-tailshaft/
  • Replies 65
I was talking to a guy that makes tailshafts in Adealide. He was telling me the longer you make a shaft the less rpm you can spin it at, when you are at around 1.3 meters you will be lucky to get 5000 rpm out of it so thats why you go multiple peice. So it may not be that smart on going to a single peice shaft depending on RPM and length.
i run a one piece carbon tailshaft, and it is almost half the weight and we spin it to 8200 rpm also its rated to 1500 hp.
cheers russ
p.s we also dont have problems anymore with driveline shudder from the centerbearing on hard launches with the carbon one piece shaft.
Edited by giant
cheers russ
Hey Russ, where did you get this tail shaft from?? Local or overseas??
GTR shafts are shorter than GTS-Ts due to transfercase on back of gearbox so they aren't that long.
Got a mail back from ACPT and my carbon shaft is on order!
ACPT driveshaft is $1400.00 for the version 1 (800 ft/lbs of torque) plenty for my circuit car, they also make a bigger one, slightly heavier and more expensive, for drag cars with up to 2000ft/lbs of torque. $200-250.00 for overseas shipping.
I'll let everyone know how it goes!
Any weight loss of a rotating part will be beneficial.
Still, from what I understand, weight is only one factor in the equation, the other is the diameter/distance that weight is located from the source.
So a lighter tailshaft may be offset by an increase in diameter of the shaft, i.e., standard 2.5" diameter standard shaft versus a newer lighter but 3" diameter shaft. I guess for tailshafts it would only be a slight increase in diameter and probably wouldn't have much effect going to a larger one..... but in terms of flywheels this is the case.
Fixxxer :)
hey mate as linked below
http://www.acpt.com/driveshaft/driveshafts.html
just dont hold you breath on there response times toook them awhile to get mine out to me , but as very happy with the product and has never failed even with heaps of abuse, no launch shudder ever!!!
and 6 odd kilos lighter
cheers russ
    • Interesting. My tuner said after the tune that my fuel economy would be better but it is the exact same from what I could tell even though my car was running rich before lol. How much do km do you reckon you get on a full tank of petrol on your commute?
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
