Changed front brake pads, because that is where the noise is coming from. its the right hand front wheel. i look at the pads and they still have a lot of meat on them, but changed them anyway with some fero's or whatever they are, but still no luck, was ok for like 2 days, but now squiling like crazy again. went to supercheap picked up some spray to clean and take away noises brakes, still no luck.
what do i do now? i pull up at the lights and once im almost stopped ( 10k's a hour ) this horrible squiling starts until i slam the brakes hard!
any idea's?
thanks
https://www.sau.com.au/forums/topic/153762-brakes-never-stop-squiling/
Itll be the discs, feel up and down them for uneven-ness and cracks. new pads will last for a bit until the cracks in the rotors cut into them and you get un-even disc/pad contact again.
You need to take the pads and the discs off and take them to a break specalist and have them machine the rotors and chamfer the pads. If the rotors are gone beyond the machining point then you will need new discs, I recomended DBA Slotted, or if you want to spend more money, DBA Slotted + Dimpeled, which are also gold passivated and zinc treated.
My front brakes were fine but would squeel like a pig just as the car was coming to a stop. My front rotors were glazed due to overheating and needed to be replaced (too thin to machine).
Fixxxer
I had the same problem, i got my rotors machined as i had plenty of meat left on em... solved my problem too
I have this problem, I had my discs machined and pads replaced and they were noisy as hell, I took the car back and they looked at it and when I got it back they were better but still noisy..
stock rotors and Lucas pads, I havnt been back since because I have a problem with assholes pretending they know my car.
I'll be trying the spray then if that doesnt work I'll pull them down myself and do them myself..
*shakes fist in hollow rage*
they were bled , and are standard brakes. ive tried anti squil spray but no good. might go for slotted discs i think, thanks for the replies
I've got project mu slotted rotors and endless pads and they squeal. Having slots doesn't stop it squealling.
Many pads these days squeal especially performance pads under light braking.Generally if the rotors are machined and the pads bedded in properly it will lower the chances of squealing.If you have the metal shims still on the pads take them off and try the stick on anti-squeal which goes on the back of the pad.These are available from Race Brakes Sydney for about $10.
If you have performance pads or the brakes were not bedded in properly it may be to late though.
I'm actually not sure what my pads are (haven't had to change them yet) but I've personally found that my biggest problem is when my stock rotors get wet. They get a layer of surface rust almost instantly!
First few stops they squeil at low speed, but after that they're ok again.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
