Hey guys,
Over the past few months my car has been making a real high pitch noise coming from the exhaust
side, so i decided to take a look, i have 2 broken studs one is at the back of the exhaust manifold an one is at the front, so my guess is that the exhaust gases are wistling on the gasket(maybe correct me if im wrong) but car has been running like crap, spiking an using a fair bit of fuel then usuall(350-400klm per tank) down to around(280-310klm per tank).
where an how much will it cost to get the studs drilled out an re-studded.
https://www.sau.com.au/forums/topic/153784-broken-studs/
depending on how bad the damage is, the studs will cost from say $80 upwards.
to give u an idea i payed 350 for 5 studs that were either broken, cross threaded, or put in crooked etc. completely stuffed.
other have payed just over 100 to take out 4 studs so i guess it depends who does it aswell
yeah that noise could be coming from the exhaust manifold gasket but get someone to check it before u do anything
https://www.sau.com.au/forums/topic/153784-broken-studs/#findComment-2859955
also forgot to add, the parts from nissan are $120 for manifold gasket, aboujt $40 for turbo to manifold gasket, and about $3 each stud from nissan
also there are locking nuts ands special washers which i think are about $3 each aswell
https://www.sau.com.au/forums/topic/153784-broken-studs/#findComment-2859959
I got a new gasket from Autobarn for 12 bucks if that helps.
Dude I remember you being in QLD yeah? If I rembered correctly head down to Auto Barn on Moss street the parts manager there has a pretty good knowledge of Nissans and as such carries a good range range of stuff that is far cheaper than Nissan
https://www.sau.com.au/forums/topic/153784-broken-studs/#findComment-2860015
yeah im in qld, the studs have snaped off in the head, i have already pulled off the turbo an had it checked out an its in really good condition, an wen i put it on i had noticed that those two studs were broken, all others are ok. i do have a mate who can do it but he doesnt get much time he has a right angle drill.
https://www.sau.com.au/forums/topic/153784-broken-studs/#findComment-2860034
shit wouldnt gotten somebody down here to do it for around 100-150 max
see these kinda jobs get shit when u dont have a hoist ya no.... otherwise piece of piss to do :sorcerer:
https://www.sau.com.au/forums/topic/153784-broken-studs/#findComment-2860232
You will probably find that your exhaust manifold is warped and will need machining before you can fit new studs (replace all of them not just the broken 1's).
From memory it cost me about $350 drive in drive away.
https://www.sau.com.au/forums/topic/153784-broken-studs/#findComment-2860747
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
