Hey,
was interested in getting into off street dragging. was interested to kno who in adelaide does it?
I just need a little advice to get started.
Whats the best way to get into it? When, where etc does it take place?
And are there saftey things that need to be done to the car?
Any help would be great.
Thanks
https://www.sau.com.au/forums/topic/153785-dragging-in-adelaide/
Yeah its been TOO long since AIR has last been functional for street drags.
Basically the car had to be in good working order and you had to have an approved helmet. All you needed was fuel and some fun!
AIR was crap because it was sooooooo slippery because it was never prepped unless it was for competitions.
and theres no bullshit
u got timeslips to prove if someones pulling their dick
this is crap! so where getting labeled as hoons and us young people are being stupid on roads yet for some of us that want to do it legally south Australia doesnt offer a place for us to do it!
Well no not at the moment........... and it's not the governments fault, it's that dickhead Bob Jane that NEVER upgraded the track, and then took Bill to court over it, which then took months! So after the court case which i believe has now ended with Bill winning, he is going to rebuild the whole place! so be patient and we will have a prime motorsports park close to town in the coming future!
yer fair enough, jus having a spit! what place he rebuilding?
If what darren is right.
Then Bill will be rebuilding the whole A.I.R raceway.
WHich is much needed as its very old now. I have not been there ever but have heard about it being very run down.
I hope it gets fixed up ASAP as yes we do need somewhere to go to have fun in the controlled environment.
I have heard rumours of the track(drag strip) bieng rotated so it's not into the sun........and also a jet boat sprint track in the middle of the circuit!
sounds good but the only problem now is, ill be dead by the time i see that happen!!!
You gotta remember though it would cost millions of dollars for someone to do a redevelopment like that.
And they gotta make money. So they need more than SAU going out every friday night to do that.
I'm sure it would do ok though as SA has a huge car scene. But they would need to attract actual drag events. With interstate and better yet international competitors.
They havent had trouble in the past. The only thing they need to worry about is pricks breaking into peoples cars in the car park. A big turn off for anyone in the past...
The biggest problem I can see with that idea is creating an area for sufficient runoff at the end should anything go wrong - the strip would have to be moved down substantially, and it would cease to be a part of the racing circuit.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
