Guest INASNT
Originally posted by DJ_L3ThAL
yer i got my powerfc done by ice, and nigel spent ages fine tuing it on ther dyno but still on cold nights and under differnt loads etc i got some pinging, i just noted when this happened and went back as i found new areas that needed fine tuning and we ironed them out within a week, think i onloy went back twice which was awesome considering now my car is 100% ;)
ho did u know it was pinging?? was the knock reading over 60% on the h/c ?
  • Replies 50
this powerfc sounds interesting....
i have not owned or study it at all....although i did test drive an r33 which had one installed... it went nice and hard....
can you tell me how much they cost and where i can find technical info on them?
after using LINK, Wolf 3d, Haltech, seeing what motec can do and studying autronic, i would love to compare.
Originally posted by king_kw13
what are big power mods Al? Is big power mods defined as
- Larger Injectors?
- Aftermarket Cam Shafts?
- Aftermarket Turbo?
- FMIC?
- Big NISMO Sticker?
First three. Forth can be delt with by the apexi, and the fifth by the wanky ricers :P.
The best programmable ecu, is the one your trusted mechanic can tune. No use having a Wolf if he has only delt with a Pfc and isn't able to extract and use all features :uh-huh:.
But if you plan to change the first three items listed above, do the ecu first, as this alone will give you a noticable differance.
my 2c
Good luck with your decision
Guest INASNT
Originally posted by Jay95R33
rs73 - yepp, that's my understanding.
I've heard 'stories' of people pluging in a new PFC and gaining 15rwkw just from the base map it comes with..
Not sure how true this is, but sounds tempting.
J
u may get a slight power increase but the car will be pining off it tits as the fuel maps r based on jap 104 RON fuel
i wish it was that simple that the best ecu is the one your mechanic can tune the best.
Personally i would, and have always had my cars tuned by the workshop the particular ECU company recommended to tune, supply and fit.
Originally posted by rs73
Al,
why you wouldn't wanna change factory IC with FMIC, considering with afm injectors, cam, & turbo?
what would be the factory IC efficiency is, don't think it will be effective for boost above 12 psi.
The original question was: what do i consider big mods to justify a ecu replacement. If you only plan to go as far as a fmic i am suggesting to use a apexi safc to trim the fuel curve. Of course you need to replace that shitty factory ic. If you are planning a turbo upgrade, etc. than a replacement ecu is a priority.
my 2c
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
