Hey guys,
Picked up a few gauges to stick in my R34 GTT skyline. They are going to replace the factory ones in the tripple gauge cluster. Only problem is tho that with the oil temp gauge i bought there was no sender included with the kit. Just a grey wire that the instrucions (if you could even class them as that!) say to hook up to the oil temp sender or something.
Anyone know if i could just tap into the wiring loom from the original gauges and use the wire that used to run the stock oil temp gauge???
https://www.sau.com.au/forums/topic/153813-oil-temp-gauge-headache/
Yeah i just tried splicing it then but the voltage output doesnt seem right. For now ive put in a few resistors so the factory gauge is reading about the same as the new gauge but this still seems very dodgy.
