Hey,
I'm looking at buying a Nissan gazelle and turning into a drift car, so i can learn to drift and gain more experience with modding cars before i am old enough to buy/drive a skyline.
I was wondering if there was any other sort of car that you would recommend for me to look at before i purchase a gazelle, that would make a good/cheap drift/project car.
Also, what engine would you recommend i put in it?
I chose the gazelle because i heard that ca18det/sr20det can just bolt straight in. (don’t really know much about engines tbh)
Heres one i am looking at there aren’t really many around :P
And about how much will it cost me to get it up and running as a drift car, not counting the exterior and interior work.
Keep in mind that i am:
17 years old
Wont be driving it around town, only on tracks
Have an income of about 160 a week
Going to put alot of time into it.
Also if you know anyone that is selling one tell me
Any help/advice would be greatly appreciated
https://www.sau.com.au/forums/topic/153849-gazelle-project-drift-car/
you need to get one with indapendant rear suspension. part from thet they make great drift machines.
Also consider an R31 skyline, they do a really good job if they have a locked diff and hard suspension they put out about 100rwkw and its just enough to get them drifting.
Cheers.
Justjap have an immaculate factory turbo S12 in their lot right now that has to be seen to be believed. It has an original 120,000km on it or something but looks like its brand new.
Could i please have a link?
That's with thier standard engine? and if i wanted to upgrade the engine in it how hard/expensive would that be?
R31/s with the standard RB30E put out very close to 100rwkw and hive quite a decent amount of torque.
their weight balance is not too bad and parts are cheap as chips :P
The best was to set one up purely for drift is strip everything out of the car just leaving 2 seats, dash and door trims and gut the rest this will help by keeping the car lighter.
then get the diff locked by welding it at about $50-100 and then buy really stiff springs far stiller than you would use on the road. around 5k rear and 7k front. they will set you back between $200 and $300
I have seen cars set up like this perform remarkably and having spent all of $1700 for the car and a set of springs and a welded diff.
you can also turbo the stock R31 engine using factory parts from a VL turbo but all up you will be looking at around $1200 for ECU, injectors, turbo, dump, crossover pipe, taking the total to $3000
and for a grand more than that you can buy an unregisterable race only import shitter like an S13.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
