ok guys on behalf of DRC and flypromotions we would like 2 thank the ppl that came down and supported the event it was a good turnout and for the ppl that missed it well u missed out on one hell of a night lol
and here is the the video of FLYGTI's exa jumping off the dyno :/:(
http://pics.blueiceco.com/josh/FLYGTI.wmv
:D
jump of the dyno? lol
its a CA18 hahahaha, guarentee not even 200kw
its called not strapping the car down properly
well for the one the car has made over 200kw on less than 20psi :O
and 2 the was strapped down but the screamer pipe burnt the strap
and lets just say this ca18 will amaze :)
very dangerous.... what ended up happening? did that bloke standing on the side get hurt?
well the sreamer pipe burnt the strap there was no damage 2 the car and no one was hit the guy doiong the dyno run managed 2 stop the car as u can see in this pic it only came off the rollers then he stopped it
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
