hey ppl have somne shit i really need to get rid of
just laying around home
i also chasing some parts basically any aftermarket parts
for an rb20 or nissan cefiro
cefiro r32 catback exaust 3 inch with 5 inch tip i think $450
standard manifold and turbo zero side to side very little back and forth $240
oil and water lines for turbo SOLD
aircon compressor $50($70 with all hoses ect.)
alternator $50
afm $200(cefiro rb20 so i have the z32 plug for extra)
rb20 manual ecu out of a cefiro $175
radiator $80
2 rb20 standard intercoolers $30 ea(no pipes)
engine wiring loom $200 (including plug to ecu)
manual tailshaft ???
lsd from cefiro???
very heavy cluch 450-500hp used including pressure plate $300
rb20 flywheel near new $50
cefiro/silvia/180/no turbo r32/33
4 stud hubs 50ea very minumal wear 3x,xxxkms
thats all i can think of i have for the rb 20 if u need anything just ask
but i also have an rb30 stainless steel turbo manifold $400
hybrid 38mm wastegate $120
and anything u need for a cefiro if i can help with anything call me on 0412938223
or pm
all parts are negotiable will post anywhere u pay post
im also willing to do swap for parts u need if u have anything i need
Edited by drftnfrysi
https://www.sau.com.au/forums/topic/153905-rb20-parts-for-sale/
  • 2 months later...
  • 1 month later...
hey the fly wheel how much posted down to sydney 2085
and if u could mesure the size of it, reason being i have a clutch kit and the pressure plate is too big for the fly wheel....
its the model number for a rb20 so my fly wheel is two small
  • 1 month later...
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
