  • Replies 109
Originally posted by silver gts-t
does anyone know of how long it takes to get up there?
From the Eastern Suburbs, it takes 3 hours on the dot along the M4 / Great Western Highway. From Merrylands, probably about 2:15 - 2:30.. Longer if we take the Bells Line of Road.
Well they are planning a stop at lithgow maccas to regroup... this should be interesting as it is not the hugest car park.
I would sat that if we leave at 9am on the dot we should be there (bathurst) between 11:30am - 12:30pm.
The biggest thing to remember is that it is a cruise with lots a cars and the cops DO know where we are going and what we are supposed to be doing. Remember to take some water and some good cruising music as radio reception is no good after about Lithgow.
See you all in the morning.
My number if you need it is 0414 940 938.
Cheers,
Dan.
Hey fellas,
I will be meeting a mate from the proton club on the corner of mona vale raod and forest way (just up from burger king) on sunday morning at 7:30 -7:40 am. The proton club are meeting at homebush and so I will go there and then to merrylands. Anyone who does not want to go to the m4 maccas meet is welcome to come with me. give me a buzz on 0404484731.
see ya guys at the merryland meet...should be HUGE.
This is Majanal posting at Bonkers house:
Red GTSt,
If you have a cb you'll be fine... if you don't then a navigator should be in order.
All,
Just remember that we are NOT meeting at the m4 maccas anymore we are meeting at strockland mall Merrylands. I just spoke to big vis and he is aware of that and informed me that he had posted the above.
Bring ya cb's guys and tune to channel 25. If you have a spare one then bring that also.
Cheers,
Dan.
0414 940 938
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
