What do i want:
I think immediate concerns are pissing whatever crappy brakes i have for the front, full brake flush, disc machining, and some good / expensive pads like greenstuff. A Strut tower brace would help front end handling (shithouse at present). A camgear will go in at 100,000km service (and its up to 97k). Some nice rear tyres i need sometime soon to get a mid-low 13sec time.
  • Replies 85
mods :
R34GTR N1 engine N1 pistons
N1 water pump
N1 oil pump
N1 head gasket
N1 head porting
N1 block
Nismo N1 R34 TwinTurbos
Nismo fuel regulator
Power Fc ECU
660cc injectors
Spitfire blue coilpack
Cusco Front LSD
Twin plate clutch
ARC Intercooler
ARC radiator
ARC 16 layered oil cooler kit+remote oil filter
Full stanliess exhaust system
Racing front pipes
AVC-R Boost Controler
Z32 80mm ARM's
HKS turbo timer
Nismo speedo 320km
5 other gauges
Recaro seat
7 point roll cage
aftermarket rear spoiler
HSK airfilters
Trust gear knob
Tein coil over suspension
SSR lightweight wheels with 265's on all 4's
Got my r33 gts-t 3 months ago and she has
-Neo6 rb25det from an r34 gt-t
-400r front bar
-Nismo side skirts
-Nismo rear bar
-Gtr wing
-3.5" zorst from the turbo back
-10" tip on zorst
-Custom high mount zorst manifold
-Stock turbo with t04 internals from cgc
-Custom intercoler piping
-600x300x72mm trust intercooler
-TurboXs RFL bov
-Forward facing plenum
-Gtr strutbrace
-Turbosmart dual stage boost controller 7psi/1.2bar
-Gtr injectors
-18" Everim wheels
-Autowatch 3 point alarm
-Nismo gear knob
-Lowerd king springs all round
-K&N pod
-Apexi turbo timer
-Wolf 3d ecu (not fitted atm)
-Autometer digital air/fuel ratio gauge
-Autometer boost gauge
-Pioneer head dick
-Pioneer splits
-Pioneer mids
-Rockfordfosgate amp
-Rockfordfosgate "12 punch subs x2
Next on the list of mods areeeee...
-Apexi PowerFC
-Apexi S-AFC
-Bosch fuel pump
-Bigger injectors
-Oil cooler
-Oil Catch can/Breather can
-Higher psi oil pump
-Nos
-Rice (neons under car)
-Rice (custom subwoofa boot install)
-Coilovers
-Bigger turbo (GT35/40 or Trust TD06-25G(Cheers niz33))
-Adjustable Cam Gears
-Daily drivable clutch
-Lightend flywheel
-Advan number 5 18" racing wheels
And thats about it :)
OK well I have spent a truck load since I bought my GTR last October & all those that know me will vouch that I've driven it about a dozen times since....  Here's a list of mods/repairs:
Motec M800 ECU
Motec Boost Controller
2 reconditioned High Flowed R33 GTR Turbo's (blew them both)
Replaced all the oil feed lines & tubes
Installed new oil filter housing gasket (none there!!!!) & inlet manifold gaskets
Replaced all plugs/leads
Reground cams
Replaced timing belt
New tyres
Adapters (spacers)
Clarion Headunit & Pioneer Speakers
New exhaust, one with a cat converter....
and on & on she goes......
Anyways one step closer
Cam :D
And becuase of that I have only driven it twice...
Ok my mods, well after that huge list of others mine seems pale in comparison...
I bought my 96 Ser II off my girlfriend, yes you read that correctly about 6 months ago...all it had was a 5Zigen exhaust cat back...with s15 mags...
Since then,
Malpassi Rising Rate Reg
Front Strut Brace (old one was removed by prev owner...rear remained)
Pod Filter (CAI yet to come...)
Repainted front bar...hit a ditch on a farm...
GFB Stealth BOV
18 Inch wheels that some GTR owner wants but unfortunately wrong offset so won't fit over the Brembo's...
Painted Calipers Red for some rice (and did it myself Joey...)
Rewired the Turbo timer and Viper alarm...
Have sitting in the lounge room...
Heavy Duty Daiken Clutch
Set of Iridium Plugs to go in when I pull the intake off to polish the cam covers...
Next on the list is...
Full exhaust turbo back leave standard dump as not changing turbo
Boost Controller after FMIC
Springs and Shocks
Not going overboard as yet, I have spent WAY to much money on cars in the past and now with a mortgage its a little hard...
Guest darrinspencer
95 33 gtst mspec manual
was stock when i got it from japan.
current mods in the last 8 months
Ford xr8 blue print paint work
Garret gt30 7psi 175rwkw
hybrid fmic
3" dump
3 1/2 s/s cat back
bosch 910
apexi pod fiilter
Greddy oil catch can
Zeal alloy body coilovers
18x8 BSA264 235 front 245 rear
nimso clear indicators
nismo gear knob
Apexi RSM
white el dials
twin apexi gauges on pillar
Greddy turbo timer
Momo race steering wheel
Alpine stereo
Rockford amp
custom s/s radiator cooling panel
33 gtr grille
Parts I have at the moment being fitted over Easter
Wolf 3d ecu plug in
remove air flow meter
Tomie exh cam wheel
timing belt
Sard fuel regulator
33gtr rear strut brace
Rear adjustable camber arms
adjustable front caster rods
Dba cross drilled and slotted front disc and greenstuff pads
paint calipers
new fully polished alloy intercooler piping (get rid of the crappy chromed alloy Hybrid piping)
group buy cold air box if it ever gets here (2 1/2 weeks in freight)
Future mods in the next months
Tune ecu 16-18psi hopefully see 240rwkw
GFB stealth blowoff valve
apexi power intake to turbo
2 way lsd
ganador mirrors
full 33 gtr interior
tomie poncams
head gasket
new clutch and flywheel
oil cooler and remote
front bar side skirts and rear bar
nismo instrument cluster
18x8 18x9 gold volk gtc
once done keep it for 3 months, sell it and start all over again, maybe a 34 gtt
its a vicious cycle.
  • 3 weeks later...
Added some more goodies to the GTR:
DBA 4000 series rotors slotted front and rear
Reconditioned APEXi T-Max coilovers with King springs (300lbs front and 225lbs rear)
Cusco rear adj camber upper arm (running -1 deg)
Cusco adj caster arm (running 5.0/5.5 deg)
Whiteline front camber bush (running -1.5 deg)
Currently sitting at a height 355mm from centre of wheel to guard.
Suspension is done, just need the sway bars. Just in time for the skidpan day!!!
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
