what is generally considered the ideal turbo for a rb20det and what kinda hp will it flow?
I you've got 10 g to spend I've either save my money - sell it and buy a gtr. OR rb30 conversion - if you've got the mechanical knowledge the 10g will go a long way towards 300+rwkw and extreme torque.
Cheers
AS ABOVE....
Or if you want to keep your car and engine and have a streetable car as mentioned speak to slide on this forum or contact GCG about getting a highflow.
Value for money they are awesome being able to keep standard manifold/dump pipe etc. You could get 220-240 rwkw out of an rb20 with right supporting mods/tune etc.
Hope that helps
Also try the rb20 thread to look at how others have gone about modding theirs and their results.
Cheers,
Ryan
ten G is a fair wack of coin my friend! you have some great options as mentioned. Get a 32 GTR would be my pick, or if you want to stick with your car, use the money to put an RB26 in there and almost have a GTR.
Best advice from myself who has seen a lot of money lost from upgrading mods i already upgraded, then got bored of: dont waste your money on the rb20 or even a 25, go an RB26 and you'll have a platform that can lazily be a 160rwkw daily to a 300+rwkw street weapon or sleeper.
Ive spent a small fortune making my rb25 pretty sweet (which in all fairness it is), but im ready to throw an rb26 in there after much time and money spent.
cheers, enjoy your spending!
Thanks for the advice mate
To go the route of an engine swap to a rb26 would 10k cover all the cost?....buying the engine, having it install with the microtech etc (i dont want to stuff around with standard comp), would the gts4 gearbox be able to stand up to the extra strain of a 26 or would i need a gtr box? More $$$
Like you say you dont want to be revisting things you have already modified and spend $$$ on because your not happy, thats why im on here, want to get in right the first time
Thank again for your help
couldnt tell you about the strengths of a gts4 box.. im sure someone will jump in and tell you if its the same as a gtr one anyway.
It depends on which way you wanna go, if you can find a 26 that you know is healthy and can just drop it in, i would think 10g would cover everything. But if you want to add some new turbos, injectors and start modding the 26 then you may be looking at more. even some decent second hand upgrade turbo's could fit your bill. Theres a fairly recent thread i started, asking cost of putting a 26 into my gts-t.
edit: http://www.skylinesaustralia.com/forums/in...152866&st=0
check out R31Nismoids posts, esp #5 to give you some pricing ideas...
But personally i think selling and finding a nice 32GTR would be best idea as at the very least youll have better brakes, seats, and not to mention a legend parked in your driveway!!
Edited by SLY33
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
