Hi :D
am new member on this forum - just few days ago I bought SKY r33 from Japan its 93 years model with hicas and lsd, i need some information about this car anyway its firs sky in Tbilisi so this forum is my only hope:) firs of all i need to know where ECU is displaced and what is turbo PSi boost??? i know its 7psi is that correct?? and what modifications shoud i do for? I have seen the intercooler on stock its so small:) will i have any extra hp or more PSI in turbo after installing intercooler kit??
please be kind and give some advice
and thanks for helping
Edited by guricha
https://www.sau.com.au/forums/topic/153945-need-help/
Welcome to Skylines Oz.
The ECU is found on the pasanger side front kick panel. This is the panel directly below the glove box. You will see a 10mm plastic nut, undo this and pull the cover off, it takes a bit of fore to unclip it, be gentel through. (if you sit in the pasanger sit, and rotate the left foot towards the outside of the car, you will hit the panel behind which the ECU can be found.)
The stock ecu runs 5psi below 4500rpm and 7psi above that, there is a hack to make the car run 7psi all the time. Look under the DIY section.
In regards to modifications, get a full exhaust, a good boost controller and posibly a new fuel pump, as skyline ones a notourious for failing, posibly a new computer or a pigyback one, and 200rwKw or 270hp at the rear wheels is easy to get.
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2863268
Wouldnt Georgia be better off with 4wds? :(
Tbilisi is a city with over million people so im sure there is lots of sealed roads
i would get rid of the hicas save 20kg in weight and makes for a better handling car
it must be cool 2 have the first line in Tbilisi
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2869893
About roads we have no problem:) I can tell you roads in Tbilisi and central magistral roads are better conditon in Caucasus:) and we have RUSTAVI track its 4.4 km long its not LAGUNA SECA but road cover is in good condition so people dont have any problem with adrenalin:) 2 days ago i Install boost gauge its shows more than 7 PSI its mneans turbo is ok, actualy this is my first Japan car because mostly Georgians are Bavarian fans:)
this is my sky i run 402 meter 13 .55 sec i think its ok for stock car without any modifications and again i have miss when changing gear from second to third:) i think i need time because i have run onle just 500 km yet, and there is video of my car and BMW 540 actualy 4.4 engine with 286 hp with tiptronic gear box and we push acceleration after 50 km in hour:) BMW 540 VS R33 GTST
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2869920
That doesn't sound like a stock R33 gtst. If it was stock, it would be in the 14's. The fact that you run over 7psi shows that it isn't stock aswellr.
Edited by jantolis
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2870006
Ah ok. Nice car you got there mate!
thanks mate:) are you Russian??:ninja:
car is completely stock without modification i check it ! opens turbo above 3000 on 4500-5000 with missfire:) and than shows 7-8 psi before that till 5... car is with original muffler and exaust system
Edited by guricha
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2871196
Mods? Exhaust - ECU - Intercooler - Boost controller? then worry about everything else! :laugh:
do you have links of this items?? where i can find them??? what you mean ECU it there any GTST ECU modifications???
and do anybody know how much i can boost turbo witout angine modification, actualy its now araund 8 PSI
thanks again:)
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2879560
thanks again:)
Hi mate,
the highes you should go is 12psi maximum, 10-11 is safer. Over 12psi and ur exhaust wheel on the turbo will blow off. you shoudl upgrade your intercoole rif your running more boost. Also get a full exhaust system.
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2880582
need help i find this intercooler kit on ebay http://images.channeladvisor.com/Sell/SSPr...FMICRSB-JDM.jpg
is it ok??? price is so cheap maybe someone sugest write address where i can buy it
thanks
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2891615
Hi mate,
Please Help!
I bought boost controller but I dont know what is recomended PSI what i can boost on GTS25T? car is absolutely stock....
Please Help!Please Help!Please Help!;)
What tmc_2 said. Go 10psi. Although if you haven't put a full exhaust system on yet, don't boost it at all. The stock system is very restrictive and you won't reap the best benefits. Intake & Exhaust & intercooler first (although its probably colder there anyway), then boost.
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2907106
Heya guricha welcome to the wonderful world of Skylines! This place is full of really helpful information and everyone on here is happy to help and wont look at you like your a dumbass for asking any sorts of questions...
Just think of your Skyline as your new girlfriend LoL ;)
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2907148
Just think of your Skyline as your new girlfriend LoL :)
Hi thanks for help you are only hope for Georgian Skyline:) please sugest intercooler kit i found them on ebay and cost araund 160$, i have no experience in that and are this intercoolers quality ok??
Edited by guricha
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2909082
Please Help!
Please Help!Please Help!Please Help!:wave:
i wouldnt be screwing any more boost into it without some better breathing. you need an exhaust, intercooler and pod filter immediately before boosting the poor stock motor.
https://www.sau.com.au/forums/topic/153945-need-help/#findComment-2911705
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
