Hey guys
Due to unforseen circumstances involving my job i think i will have to sell my R32. I'm not ready to sell as i really love the car, but unfortunately i may not have a choice.
I really love this car, i have previously owned 2 silvias and 2 33's, so i know abit about imports and how to look after them. It is serviced every 5000km with motul 300V oil. I wash the car weekly and keep it as clean and immaculate as possible. I have never had any problems with this car in the almost 1 year i have owned it.
For Sale at: $13,000 as is
$12,500 without the bride seat, harness, and the extra parts listed at the bottom.
Will come with RWC
Located in Melb.
1992 R32 Skyline GTS-t
Black
5-speed manual
Sunroof(has been retrimmed/serviced recently, seals are great and no leaks)
153,xxx genuine km’s
Major service has been done
Registered till august
ENGINE
B&M Oil cooler with thermostat
Oil filter relocation kit
Dr Drift remap
3" Dump and front pipe
3" Catback with midmuffler and larger JASMA approved rear muffler(very quiet)
Nismo fuel pump
Car has made 150rwk as is on Dr Drifts dyno. Running good AF ratios. Have a dyno sheet also.
DRIVELINE/HANDLING
Simmons FR17(great condition)
Rays lightweight wheel nuts
BF Goodrich Profiler 235/255 tyres with good tread
Koni Adjustable Height and Damper suspension(legal height)
Redline Lightweight Shockproof gearbox oil
BRAKING
RDA Slotted rotors front and rear
Racebrakes RB74 front pads
Racebrakes Comp 2 rear pads
Braided brake lines front and rear- ADR approved
Cusco brake master cylinder stopper
Motul RBF600 brake fluid
EXTERIOR
Genuine GTR bonnet
Genuine GTR front bar
GTR grill
Gtr style sideskirts
Carbon fibre GT wing
Tinted windows
Clear corner indicators
Clear side indicators
INTERIOR
Bride Zeta II seat(have stock seat)
RPM 4point harness
Momo steering wheel
Detachable boss kit
Momo gearknob
Nismo gearboot
Nismo handbrake boot
Greddy turbo timer
Boost gauge
CD player
Fire extinguisher
Also comes with these parts which are not fitted:
Project MU front brake pads, Pod filter with adaptor, Arospeed adjustable cam gears, HKS intercooler, Noltec rear subrame mounts, Hicas lock bar, GTR rear wing.
Negatives about the car:
The bootlid has some scratches which occured during the removal of the gtr wing, it will come up good with a cut and polish.
https://www.sau.com.au/forums/topic/153950-mint-r32-for-salemelb/
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
