  • Replies 48
Posted Images
shaun was pretty happy with it being a r33 auto.
obviously the 3k high stall and trans is robbing a bit of its power potential, but all in all im happy.
its very smooth until you here the turbo start whistling.
past that its actually a bit crazy.
Very Nice, was a touch warm today also. Nice cool day and you'll see that 300rwkw. :stupid:
Turns out I have a few questions.....
The 11 power runs? Did Shaun have a fiddle?
Did you get to the bottom of the lack of top end? Suspected torque converter?
not sure i wasnt there.
i think he did two runs one after the other so heat soak and molten tyres would show up.
299.9 then 296.8
its at a constant 24 psi which shaun thinks is a good happy number on shell 98.
the afr is now in the low 11's once boost starts, to redline in a constant line, which is something that John never managed to achieve, and knock is maxing out at 18. but averaging 12.
im not sure if im still missing 50 kws or thats all it has in it with the standard nissan head gasket?
with the 3000rpm high stall it will do a 11, so for a daily driven shopping trolley i might leave it alone for a while and just enjoy it.
cheers
Charge takes only an hour or so. :(
My sister currently has the video camera but I can grab it easily.
RE: The std Nissan gasket. I have no idea.. Its doing pretty damn well. its not o-ring'd I presume?
I've seen cometics around pretty cheap ~$200-$250.
how come you took it to shaun this time and not john?
mainly to get shaun to fine tune my pfc boost ccontroller setup as he has had some really good results with them, and John thinks there crap/doesnt know how to set them up well.
also as my first visit to Boostworx i figured i should go see what all you guys rave about..
top bloke..
top bloke..
fairy muff, so how do u find to pfc boost controller? I'm looking into getting one when i have a bit more money to spend!
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
