Dont flame me .. I just asked a audio expert .. An installer not a seller
Dynamatt doesnt do much .. It reduces slight vibration but cheaper options also work well .. In his opinion he said its not worth it .. Oh this was in the boot .. in the doors hes all for it .. but still says its better just to do the surrounds to reduce weight ..
Out of interest, what were the cheaper options he mentioned?
well one was expanding foam (rookie told me that one and no way I would do it ..)
He explained padding foam would work if its hard packed and making sure everything is tight... He told me cheaper version will do just as good but we had the system running (boot closed) I grabbed the spoiler to shut the thing up and he said thats what dynamat will do.. It was a noticable difference but not $100-200 worth of it .. even tho the system it worth 50 times that much he still didnt feel you would hear the effects in the cabin ..
Edited by DECIM8
Dynamat is not made to reduce rattles, unless you use the one thats specifically designed to reduce rattles.
I would tell your installer mate to go back to school and have a few more lessons in dynamat and reduction of road noise.
Also EXPANDER FOAM do you even begin to understand the catastrophis results EXPANDER FOAM will have on your panels when it starts expanding? Its been known to warp the cars panels.
George
Edited by Adelaideprosound
Im just preachin his word... Obviously he'd know something.. hes been in the business for 10 yrs so I dont know..
Everyones got a opinion so i guess thats his .. not that I dont believe u either but id like to hear before I buy..
One more thing I doubt hes studied it hes just used it and felt it was worth less..
Well i use it and have demonstrated the differences time and time again. So i dont mean to sound arrogant but perhaps he was using it to STOP RATTLES not to REDUCE ROAD NOISE.
Dynamat is proven all over the world as being worth its weight in gold, and is being used by every single high end installation expert and SQ nut.
Lets agree to disagree, but when applied correctly and utilised properly Dynamat does a LOT.
How much would it cost to do a DECENT sound deadening job (diy of course)?
I knwo that everyone's decent has a different meaning, but lets just say such that the car becomes significantly quieter so that you can actually hear it. Not like a 1db drop that can only be detected using a db metre.
Would that just be doing both doors?
possibly parts of the boot/rear quarters?
underneath the rear seat?
rear seat sides?
floor?
roof?
behind dash?
$300ish for dynamat bulk pack, dynaxorb and a bottle of prepsol.
the rest is elbow grease.
a bulk pack should do both doors and leave you enough to get stuck into the boot and some under the rear seats if you haven't had enough fun yet.
alternatively, phone a friend and you could probably do the doors on two cars (with more dynaxorb for the other car) and see how it sounds.
if you want to go further at a later date then save up and buy another pack of dynamat and a few beers.
best way :laugh:
or work it on this: 88/hr average 3-4 hours to do a car and a box of dmat.
Just to respond I dont disagree with u .. from the info i got it was exactly as you say worth its weight in gold. But hey I might give that gear a go neways with a 40kg enclosure in the boot aint like 10kg is gonna hurt my ride any more ..
    • On the compressor side it looks like the best, if your head setup will support doing 100-110lb/min at 30psi-ish boost.   The G45-1350 compressor looks ideally better if you need closer to 40psi for it, given both the G40 1150 and G42 1200 look like they'll be around the 100lb/min mark at 35psi and dropping from there.   Bear in mind the turbine sides are all different between those three turbos, so that COULD be an influencing factor for how they all perform in the real world as well.   Not sure if you've made a conscious decision to only look at Garrett or not, but at least on paper the XRE7169S matches or beats those other three at everything from 30psi up and just going from wheel size alone likely to be at least as responsive as the G40 1150 and seem to behave closer to G42s in terms of turbine flow.
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a one-time tool to do something, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
