Just wondering if this oil is any good? I know you all recommend much more expensive oils but things are tight for me at the moment. The guy at the shop did say this oil was recently compared to Mobil 1 Synthetic and was superior.
Has anyone heard anything bad about this OIL concerning Skylines??
I am draining the shit oil out tomorrow. I have blown no smoke and cant see any leaking anywhere but on the dipstick it is getting lower. I have heard this means the motor does not like the oil it currently contains.
Also what is the model number of the NGK sparkplugs ( the normal plugs) for the 'line and what should I gap them at (I have stocker except for air filter)
Thanks people.
https://www.sau.com.au/forums/topic/15408-bp-visco-5000/
number for plugs is BCPR6E from memory but u should recheck
u can get it from Marlows / Repco and get a gapping tool as well ($2) and gap them to 0.8 coz they come gapped at 1.2
just under 4 bucks for one and havent had any issues with it so far (no misfiring) seems to be doing well
https://www.sau.com.au/forums/topic/15408-bp-visco-5000/#findComment-314881
yeah my plugs were changed just recently - nissan come out with platinums and a few mechanics will recomend them to u but normal $4 do just as well. :D
Ive got Redline in the Skyline but my 300ZX has Visco in it and i havent had any probs with that oil :)
https://www.sau.com.au/forums/topic/15408-bp-visco-5000/#findComment-315957
Mobil 1 is tried and tested amongst us so it is the go. Others have their preferences but all go for the well known brand name stuff... So there is something in that.
Plantiums are a matter of opinion. If I change normal NGK R's every 20,000 I am still saving from buying the Platiums.
Your choice.
https://www.sau.com.au/forums/topic/15408-bp-visco-5000/#findComment-316102
I just bought 5L of visco 5000. The specs look good on paper (https://www.distributor.bp.com.au/wls/servl...?cid=13&scid=14), but the true test is how it works out in real life use.
I've had enough of paying $50+ for Mobil 1, so I'm switching if this stuff delivers the goods. (Unless Strich9ine can get us all a piece of that $35 Mobil action :P ).
https://www.sau.com.au/forums/topic/15408-bp-visco-5000/#findComment-330061
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
