Hey guys & gals
Using a couple of other forums now that have smaller limits as to what you can have in your sig, and was wondering if someone wanted to have a play with some pics and see what they can come up with for me :( I don't have photoshop, and i'm really not that creative, so any help would be awesome! I have no particular layout requests, just that the final sig include somewhere, the words impact_blue along with the following pics
As I said, I have no experience with these things, so if someone has an idea that can't use the pics given, but I could possibly supply some others, lemme know.
Cheers, Anna.
https://www.sau.com.au/forums/topic/154086-sig-request/
lawl. Thanks spammeh.
I have had a thought, and I would like the kitty and the words to be kind of faded into the anime pic. Like, the anime pic is the main sort of 'feature' and the words and kitty are layered over it...
:no: Am i making sense
https://www.sau.com.au/forums/topic/154086-sig-request/#findComment-2866004
WAIT! I've just been looking closer, and i've realised kitty is wearing her bow on the wrong side. Mimmy, her sister, wears her bown on the left (as we are looking at her). Kitty's bow is on the right side (as we are looking at her). Are you able to change this for me puuuuhleeeeease?
https://www.sau.com.au/forums/topic/154086-sig-request/#findComment-2867560
Hey there im glad u like the sig..but i am a bit confused about this kitty thing sorry haha
I'll do a quick change if i can.. but are u reffering to the kitty next to the name that has the bow on the wrong side or the kitty from the exhaust pipe faded on the left of the sig that has the bow on the wrong side
https://www.sau.com.au/forums/topic/154086-sig-request/#findComment-2868919
she is refering to the kitty on the exhaust pipe..
CORRECT! Sorry for confusing you :P The bow on the kitty exhaust pipe is on the incorrect side. Just needs to be flipped.
And tell me to take a hike if i'm pushing my luck... but while you're at it, can you replace the kitty near the words with the cherry blossom below? Just the flower, not the black bits around it...
Thanks heaps!! :sorcerer:
https://www.sau.com.au/forums/topic/154086-sig-request/#findComment-2869302
