Hey guys & gals
Using a couple of other forums now that have smaller limits as to what you can have in your sig, and was wondering if someone wanted to have a play with some pics and see what they can come up with for me :( I don't have photoshop, and i'm really not that creative, so any help would be awesome! I have no particular layout requests, just that the final sig include somewhere, the words impact_blue along with the following pics
As I said, I have no experience with these things, so if someone has an idea that can't use the pics given, but I could possibly supply some others, lemme know.
Cheers, Anna.
https://www.sau.com.au/forums/topic/154086-sig-request/
lawl. Thanks spammeh.
I have had a thought, and I would like the kitty and the words to be kind of faded into the anime pic. Like, the anime pic is the main sort of 'feature' and the words and kitty are layered over it...
:no: Am i making sense
https://www.sau.com.au/forums/topic/154086-sig-request/#findComment-2866004
WAIT! I've just been looking closer, and i've realised kitty is wearing her bow on the wrong side. Mimmy, her sister, wears her bown on the left (as we are looking at her). Kitty's bow is on the right side (as we are looking at her). Are you able to change this for me puuuuhleeeeease?
https://www.sau.com.au/forums/topic/154086-sig-request/#findComment-2867560
Hey there im glad u like the sig..but i am a bit confused about this kitty thing sorry haha
I'll do a quick change if i can.. but are u reffering to the kitty next to the name that has the bow on the wrong side or the kitty from the exhaust pipe faded on the left of the sig that has the bow on the wrong side
https://www.sau.com.au/forums/topic/154086-sig-request/#findComment-2868919
she is refering to the kitty on the exhaust pipe..
CORRECT! Sorry for confusing you :P The bow on the kitty exhaust pipe is on the incorrect side. Just needs to be flipped.
And tell me to take a hike if i'm pushing my luck... but while you're at it, can you replace the kitty near the words with the cherry blossom below? Just the flower, not the black bits around it...
Thanks heaps!! :sorcerer:
https://www.sau.com.au/forums/topic/154086-sig-request/#findComment-2869302
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
