My car has finally arrived from japan. im at the stage where im chaging the things that need changing, removing the things that need removing. ive come across these yellow reflective stickers on my wheels (2 on every wheel) i dont know what they were for or who put them on, but they look stupid. they must have been on for a very long time. now they are crispy and really stuck on hard. ive tried to pick them off with my fingernails, but that only led to sore nails. ive tried a razor blade. but breaks off in little flakes. not to mention scratching the rims. does anyone know of anything that will take these off?
https://www.sau.com.au/forums/topic/15413-crispy-sticker-removal/
thanks guys... still a lot to do yet. the hairdryer worked pretty well. even so, havent got it all off yet. fingernails are definitely not working. razor blades is cutting into and scratching the powdercoating of the wheel. any suggestion of utensil?
the stickers are ****in stubborn! shellite? sounds cool, where can i get it? getting the gooey stuff off doesnt seem to be the problem. the gooey stuff is between the sticker and the wheel. there are two layers on top of the wheel im talking about here. trying to get the sticker itself off is the main problem. its flakey when picked at (not cracked), yet hard. trying to get past the sticker to get to the sticky stuff is the problem at the moment!
You can usually get it at a supermarket with a big range of metho, kero, dry cleaning fluid etc. (it is another variation of same).
Sounds like persistence might be the only way to get it off!! Have you tried a plastic knife? (sharp and fine edged yet not as harsh and damaging as a metal one).
thanks guys.... i finally figured a way to get off the top layer easily. KARCHER it! yup, i used 2000psi of water and blasted the sucker off! left the goo behind, but thats not a problem. thanks for all the suggestions guys. really helpful.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
