My car has finally arrived from japan. im at the stage where im chaging the things that need changing, removing the things that need removing. ive come across these yellow reflective stickers on my wheels (2 on every wheel) i dont know what they were for or who put them on, but they look stupid. they must have been on for a very long time. now they are crispy and really stuck on hard. ive tried to pick them off with my fingernails, but that only led to sore nails. ive tried a razor blade. but breaks off in little flakes. not to mention scratching the rims. does anyone know of anything that will take these off?
https://www.sau.com.au/forums/topic/15413-crispy-sticker-removal/
thanks guys... still a lot to do yet. the hairdryer worked pretty well. even so, havent got it all off yet. fingernails are definitely not working. razor blades is cutting into and scratching the powdercoating of the wheel. any suggestion of utensil?
the stickers are ****in stubborn! shellite? sounds cool, where can i get it? getting the gooey stuff off doesnt seem to be the problem. the gooey stuff is between the sticker and the wheel. there are two layers on top of the wheel im talking about here. trying to get the sticker itself off is the main problem. its flakey when picked at (not cracked), yet hard. trying to get past the sticker to get to the sticky stuff is the problem at the moment!
You can usually get it at a supermarket with a big range of metho, kero, dry cleaning fluid etc. (it is another variation of same).
Sounds like persistence might be the only way to get it off!! Have you tried a plastic knife? (sharp and fine edged yet not as harsh and damaging as a metal one).
thanks guys.... i finally figured a way to get off the top layer easily. KARCHER it! yup, i used 2000psi of water and blasted the sucker off! left the goo behind, but thats not a problem. thanks for all the suggestions guys. really helpful.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
