yes take them back and get 7s. in fact, personally I'd take them back and get some copper NGK 7s. BCPER7ES from memory. cost about $18 for a set of 6 instead of $18 each. you should be checking and replacing fairly regularly anyway and doing that with iridiums or platinums gets pretty pricey at $120 a change.
https://www.sau.com.au/forums/topic/154130-spark-pluggssss/#findComment-2866535
Sorry to jack the thread... but i'm actually looking at buying normal plugs but i duno the exact part number, i purchased the iridum type but everyone is right you need to change em regularly and $120 each time is a bit pricey... i'd just like confirmation if this is the correct part number BCPR7ES or BCPR7ES-11? and them gap em to .8? Thanks everyone..
https://www.sau.com.au/forums/topic/154130-spark-pluggssss/#findComment-2866657
Excellent thats just what i did 3 bucks each in stead of 18 and you can change them every oil change or not and i get the same fuel economy from the cheaper ones two
https://www.sau.com.au/forums/topic/154130-spark-pluggssss/#findComment-2866723
Are you saying the copper ones ARE BETTER or are you saying the copper ones are just cheaper and will OUTPERFORM iridium IXs. a set of 6 will cost u around 90 bucks that isnt much and it makes a GREAT spark. Iridium outperforms Copper. FACT.
Edited by Pauly33GTS-t
https://www.sau.com.au/forums/topic/154130-spark-pluggssss/#findComment-2867226
I think what they're saying is that you'll change copper every oil change which would be what? <5k? as apposed to changing every second oil change with iridium <10k?? I was reading on the net about the iridums and they give a whole 2kw difference in performance apparently (dyno proven)... but again if anyone can help me with part #'s for copper for a rb25det that'll be great. So in effect you can buy 5 sets of copper for 1 set of iridium... even if you change em every 2-3k your still in front i guess... anyone would like to shed some light on this?
https://www.sau.com.au/forums/topic/154130-spark-pluggssss/#findComment-2867342
the platniums should restand heat and abuse more than the coppers.. less prone to heads being blown off. but they still lose efficency within 10k.. so may aswell replace them. using the coppers ull save money and change them at the same intervals...
whats the exact part number for the RB25DET Neo for 0.8mm coppers.?
i got $8 each platnium DENSOs for the R. bit better than coppers for $3
https://www.sau.com.au/forums/topic/154130-spark-pluggssss/#findComment-2867380
Please read the sticky FI Guide.
There is a link to a very very long thread about spark plugs, types, ranges, whats good/whats not etc etc :wave:
Someone took the time to type it up, do them the justice and have a read of it :huh:
https://www.sau.com.au/forums/topic/154130-spark-pluggssss/#findComment-2867544
BCPR7ES is what you want. they come gapped to .8mm. the ones that end in -11 come gapped to 1.1mm... just a note, no matter what you buy always check all the gaps before installing them.
https://www.sau.com.au/forums/topic/154130-spark-pluggssss/#findComment-2867561
so is the 7 the heat range and what the S stand for?
bcpr7eS
is ther a way to read plugs like tyres. eg235/45/17 66V whatever it is?
https://www.sau.com.au/forums/topic/154130-spark-pluggssss/#findComment-2867734
B-thread diameter hexagon
P-construction (ex. p-projected insulator nose. m-compact type)
2-11-heat range
E-thread reach
S- firing end construction (eg. s-copper core centre electrode(super))
9-20-Wide gap (eg. 9-0.9mm-20-2.0mm)
hope this helps
Edited by johnbarry88
https://www.sau.com.au/forums/topic/154130-spark-pluggssss/#findComment-2868132
I've been looking at this thread and it seems to kind of answer everyones qustion, I think this is what nismo dude what referring to cos theres A LOT of info here...
http://www.skylinesaustralia.com/forums/in...howtopic=104405
https://www.sau.com.au/forums/topic/154130-spark-pluggssss/#findComment-2870191
this was just jap who sold them to me. and i asked if they were the right heat range, and he said yes and sold them to me.
then when i showed my mate he said i should take them back.
well from memory he's right. they are the heat range specified in the workshop manual. so it's not really his fault for selling them to you. but what I know that he doesn't is that you are running aftermarket turbos, and lots of boost, and planning track use so with that in mind 1 heat range cooler is advisable. so in short, swap them for some 7s.
https://www.sau.com.au/forums/topic/154130-spark-pluggssss/#findComment-2870204
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
