My headlights seem to be pointing more or less straight into the ground. Meaning I can see nothing more than about 1m in front of my car. It's starting to bug me. A mate of mine reckoned you could adjust the position of the lights, which I assume is why they are pointing into the ground not out in front of me. Can you adjust the R32 headlight angles? If so how? If you can't is there anyway I can resolve this issue? I want to get HIDs at some stage and there seems to be little point if my lights arent actually going to be doing their job.
https://www.sau.com.au/forums/topic/154136-adjusting-r32-headlights/
I have this same problem, my lights point very far down. I've seen in the GTR manual you are able to adjust them. but the picture isn't very clear and I cant see what has to be adjusted. could someone post a picture for us? Would be a great help. Cheers
You sure can adjust them. It's very easy. There is one bolt for adjusting height and one for adjusting left right. Take a look behind the headlight.
On the r33, it's an 8mm head.
There's not a lot of space, so you'll need to use either a 1/4 drive mini ratchet and extension or a spanner
You just turn it and watch which way it goes.
PS: r32 headlights are really really bad. Everyone always winges about them, so adjusting it might extend the range, but there isn't physically a lot of light, so by pointing it further, it'll be less bright in the area that it does shine
sorry for the late reply - internet at home stopped working :D
anyways here they are (both pics are for the RHS light but its the same on the other side)
there are 2 screws - one for up&down and one for left&right:
(cant remember which is which but it is obvious once you start tunring - haha)
(note the second one has those lil plastic gears inside - one of mine were f$%ked so had to open it like in that last pic and wind it manually)
cheers zennon.. big help.. mines like that too winding the height does nothing so my gears must be broken too.. ive just installed hid headlights on my r32 projectors.. looks very nice and so much more clearer using standard r32 wiring! highly recommended
is it hard getting the lower screw off the housing? not much room there
Hey mate post pics of the HIDs. I'm keen to see how they look. Which brand of HID did u go for?
ZENNON, the adjustment that has the gears does NOT adjust height... the height screw is located towards the underside of the projector.. it looks exactly like the horizontal adjustment screw... im assuming the adjustment via the screw that has the gears is for focus.. but winding mine all the way left and right does not focus anything.. its gotta do something..
here is a pic of my hids... the photo does not do justice to how they really look at night.. more purple/white as i have the 8000k colour temperature hids.
The one with the gears adjust the highbeams. I think it adjusts it up and down.
Cheers
hey sky20det, as patto1234 said what HID globes did you get? They do look heaps better than the stock globes.
i got 8000k colour temperature lights from a friend who got them overseas. if u really want a set i might be able to hook u up... 32w, 8000k H3 hid xenon lights. note the r32 projectors take H3C globes but as most will know, the H3C and H3 are the exact same shape and base, thus making it perfect to use H3 HID globes.
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
