My headlights seem to be pointing more or less straight into the ground. Meaning I can see nothing more than about 1m in front of my car. It's starting to bug me. A mate of mine reckoned you could adjust the position of the lights, which I assume is why they are pointing into the ground not out in front of me. Can you adjust the R32 headlight angles? If so how? If you can't is there anyway I can resolve this issue? I want to get HIDs at some stage and there seems to be little point if my lights arent actually going to be doing their job.
https://www.sau.com.au/forums/topic/154136-adjusting-r32-headlights/
I have this same problem, my lights point very far down. I've seen in the GTR manual you are able to adjust them. but the picture isn't very clear and I cant see what has to be adjusted. could someone post a picture for us? Would be a great help. Cheers
You sure can adjust them. It's very easy. There is one bolt for adjusting height and one for adjusting left right. Take a look behind the headlight.
On the r33, it's an 8mm head.
There's not a lot of space, so you'll need to use either a 1/4 drive mini ratchet and extension or a spanner
You just turn it and watch which way it goes.
PS: r32 headlights are really really bad. Everyone always winges about them, so adjusting it might extend the range, but there isn't physically a lot of light, so by pointing it further, it'll be less bright in the area that it does shine
sorry for the late reply - internet at home stopped working :D
anyways here they are (both pics are for the RHS light but its the same on the other side)
there are 2 screws - one for up&down and one for left&right:
(cant remember which is which but it is obvious once you start tunring - haha)
(note the second one has those lil plastic gears inside - one of mine were f$%ked so had to open it like in that last pic and wind it manually)
cheers zennon.. big help.. mines like that too winding the height does nothing so my gears must be broken too.. ive just installed hid headlights on my r32 projectors.. looks very nice and so much more clearer using standard r32 wiring! highly recommended
is it hard getting the lower screw off the housing? not much room there
Hey mate post pics of the HIDs. I'm keen to see how they look. Which brand of HID did u go for?
ZENNON, the adjustment that has the gears does NOT adjust height... the height screw is located towards the underside of the projector.. it looks exactly like the horizontal adjustment screw... im assuming the adjustment via the screw that has the gears is for focus.. but winding mine all the way left and right does not focus anything.. its gotta do something..
here is a pic of my hids... the photo does not do justice to how they really look at night.. more purple/white as i have the 8000k colour temperature hids.
The one with the gears adjust the highbeams. I think it adjusts it up and down.
Cheers
hey sky20det, as patto1234 said what HID globes did you get? They do look heaps better than the stock globes.
i got 8000k colour temperature lights from a friend who got them overseas. if u really want a set i might be able to hook u up... 32w, 8000k H3 hid xenon lights. note the r32 projectors take H3C globes but as most will know, the H3C and H3 are the exact same shape and base, thus making it perfect to use H3 HID globes.
    • Standard GTRs are boring and there plenty of them, do what ever you want to it and just remember nothing about them is cheap anymore and if you’re picky about how you want things done it gets even worse.    if it’s an n1 or something very limited then maybe care more about it’s heritage
    • Alright guys, I've got good odds the motor survives due to a majority of spare parts. Who's taking bets on clutch, who's on transmission, and who's go diff? Happy to also take bets on if it still overheats in traffic or not 😛     Car looks amazing by the way. I've never been a fan of R34 rears, so really, I don't think any body kit etc solves that for myself, but the front end looks amazing!
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
