4 16" Stock rims, no rubber, good condition - SOLD
series 2 boot lid and spoiler, white, exec cond - SOLD
dash cluster series 2 exec cond - $120
l/h rear tail lamp white, exec cond - SOLD
greddy bov, not sure which one - SOLD
series 2 steering wheel, no air bag - $50
series 2 rear seat for the back, not the bum bit - SOLD
power steering pump - $100
drivers side door trim, little mark in it, series 2 - $80
air condition pump - $150
sustec heavy duty shocks/coilovers .. front only, - $200 exec cond
stock diff - SOLD
r/h front guard white - SOLD
also have plenty of other parts from series 2 wreck ..
email me if you need photos, but it is a little hard to get a camera atm but ill try my best
[email protected]
Edited by braadz
https://www.sau.com.au/forums/topic/154139-r33-parts/
