Sauwa Drag Racing, Wed 21st Of Feb
GTS-t VSPEC
 Share
guys im very intersted however how does it work with insurance etc incase anythign happens or wateva ?
most insurance companies I know of, do not cover anything that happens on a circuit (drag strip or track, etc)... but if you can drive your car in a straight line though maybe it's not the place for you. it would have to be a very wild launch and gear change to slap the wall.
  • Replies 228
I might be up for this provided I can get back to Australia in time (in freezing cold Norway at the moment) and then only if I can quickly get the car tuned/looked over as it is running like a pig at the moment.
fingers crossed!
might come if i can scrounge up $40 and a helmet, still gotta pay a $350 fine so not too sure about this one
>< it's a month from now~~ I'm preety sure you can get that amount...
kinda shy going heys, engine's stock...prolly run high 14s? lol
this sonds good day befor my birthday so it can be my gift to myself might need to get ckutch looked at first any one know a good cheap clutch place thing mine is almost worn out
on another note , what are the helmet requirements ? is a basic open face helmet ok ?
Open faced is fine as long as it complies to australian standards. If it does it will have the aus standards sticker on it (red and silver or white sticker with ticks on it).
The scrutineers look for that sticker.
I've dragged some of this up from the last time we went.
Scruitineering will be looking for all the usual stuff...Battery secured, seatbelts in good nick, no leaks, windows not cracked, no religious figureens on the dash or hangin from the mirror...its a secular sport you know!
What you need: $, Half a tank of gas, no extra weight, no loose objects, brakes in good nick, a tyre pressure guage if your going to fiddle with your pressures, long sleeved shirt or jacket, no shorts, enclosed shoes. A rag to wipe of the shoe polish from the window and a will to have fun
Welcome to another night of enjoying your car responsibly and picking up after yourself :laugh:...and bring a drivers license
 Share
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
    • And over it. Need to stop it coming through the floor.
    • Is it running the standard ECU? some sort of data log might help understand where timing, AFRs etc are at.  If it is standard ECU something like Nissan Datascan would help
