  • Replies 228
eyy bro when did ya do your engine??
your wheels were just looking and goin sick eyy?
what you do excatly to it?
join the club my donks fuct 2 :dry:
he doesnt know :O he thinks it was too much bee-r but i think it had something to do with the fact he was playing around with the injector setup on the pfc h/c ahaha
#5 has a nice compression of like 60 hehe :(
despite what people think, ignition cut rev limiters like bee-r ones are quite harsh on engines. as you can imagine a huge flame going through the head/manifold and turbo doesnt exatly help things. when i had one on my sr20, i broke 3 rocker arms simply because of the strain it places on the head. Since i have gotten rid of it the engine has never been better
this is true, however the Bee*r limiter only cuts sparks at red line, unless you hold the red line for extended time, the damage will be minimal and gradual.
What Exactly is a Beer Limiter?? can someon Pls explain thanks
-JuLiuZ
what i gather from what ive seen and read, its a devise that cuts spark at a preset rev limit or at the rev limiter, so when you hit that point it doesn't spark, but dumps mass fuel/air into the exhaust and then (i think) sparks as it is exiting(?)
this is why it pops and farts and shoots flames out the zorst and thats why it puts strain on teh engine as exploding fuel/air expands very rapidly, stressing and fatiguing metal
So it's Sorta Like Anti-Lag wif the Back Popping Action eh???? hehe :)
-JuLiuZ
So it's Sorta Like Anti-Lag wif the Back Popping Action eh???? hehe :D
-JuLiuZ
not really, antilag retard timing and works throughout the rev range and does not cuts sparks, allow some fuel to escape....hence more damaging
where Bee*r cuts spark at red line, so cold fuel will exit and detonate at the manifold instead.
I dun get tho, I thought fuel will detonate at certain pressure anyways, the sparks are just there to give a more regular timing
it would but normal combustion engines dont create enough pressue, but thats how diesel engines work, no spark plugs in them
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
