  • Replies 228
eyy bro when did ya do your engine??
your wheels were just looking and goin sick eyy?
what you do excatly to it?
join the club my donks fuct 2 :dry:
he doesnt know :O he thinks it was too much bee-r but i think it had something to do with the fact he was playing around with the injector setup on the pfc h/c ahaha
#5 has a nice compression of like 60 hehe :(
despite what people think, ignition cut rev limiters like bee-r ones are quite harsh on engines. as you can imagine a huge flame going through the head/manifold and turbo doesnt exatly help things. when i had one on my sr20, i broke 3 rocker arms simply because of the strain it places on the head. Since i have gotten rid of it the engine has never been better
this is true, however the Bee*r limiter only cuts sparks at red line, unless you hold the red line for extended time, the damage will be minimal and gradual.
What Exactly is a Beer Limiter?? can someon Pls explain thanks
-JuLiuZ
what i gather from what ive seen and read, its a devise that cuts spark at a preset rev limit or at the rev limiter, so when you hit that point it doesn't spark, but dumps mass fuel/air into the exhaust and then (i think) sparks as it is exiting(?)
this is why it pops and farts and shoots flames out the zorst and thats why it puts strain on teh engine as exploding fuel/air expands very rapidly, stressing and fatiguing metal
So it's Sorta Like Anti-Lag wif the Back Popping Action eh???? hehe :)
-JuLiuZ
So it's Sorta Like Anti-Lag wif the Back Popping Action eh???? hehe :D
-JuLiuZ
not really, antilag retard timing and works throughout the rev range and does not cuts sparks, allow some fuel to escape....hence more damaging
where Bee*r cuts spark at red line, so cold fuel will exit and detonate at the manifold instead.
I dun get tho, I thought fuel will detonate at certain pressure anyways, the sparks are just there to give a more regular timing
it would but normal combustion engines dont create enough pressue, but thats how diesel engines work, no spark plugs in them
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
