my fastest for the night was
ET - 12.285
Terminal - 111.94mph
Reaction - 0.690
60' - 2.034
was a little higher boost than my street setting (ran it at 1.1bar)
I considered it a win for the night as it was a good virgin run for the R and I didn't break anything!
With some quick times posted and I think we surprised some of the trev's. Good turn out and variety of cars... Paul really put the "turn" in "turn out"... tonight I pray that someone has that on film!
  • Replies 228
Top work Paul, 125mph is massive, thats making some huge power.
My first run in the new R, kept the AVC-R switched off (0.9bar) and still ran 110mph.
Unfortunately the long first gear ratio of the OS cross set box combined with the 2835's means that even a limiter launch bogs down. 2.1 was my best 60' of the night.
Will be good to see what it runs when it's tuned and boosted next thursday.
Edited by Brockaz
i think dan may have got paul's spin on vid, but im not sure
apparently a 125mph is good enough for a 10 second pass - but he just couldn't get the power down. Watching him race and he was spinning it still on half track - but one 'advantage' of the power meant that he did some awesome burnouts
a few of you guys did some limiter bashing burnouts - sounded and looked good :P
AND michael ended up running with his hazards on, and lost to paul in the same race :P
Yes, after the first pass on slicks and a close call with the wall I was relagated to using street tyres, which didn't make for any fast times, but still a great night.
If someone has footage of the spin then please post it up :)
In a total of 4 passes I spun, shredded my wheel nuts, and blew off my intercooler hose. But it could have been much worse. At least I gave the commentators something to chat about :kiss:
mitchy what happened to your car??
only did one run eyy then took off and saw some smoke coming form the rear... turbine eyy???
What did happen to his car?? I was racing him at the time. Just as i pasted the line I looked in my review mirror to see a heap of smoke from his car... Hope its nothing to bad.
lol my mate went down in his blue 99 wrx ended up getting 13.1 , he also mentioned he saw a "FU**IN MAD" skyline that got shit times cos of lack of traction and he slide out aswell lol,,
also said he saw a white skyline with smoke coming out the back???
This kinda sums up my night :laugh:
$1400 for PFC and Boost Controller
$600 for fitting and tune
$1000 new clutch
$40 Entry to the drags
Gaining 40rwHP more than before on same dyno
Yet only running .2 seconds quicker over the quarter with slower MPH than before.
PRICELESS :happy:
(FTR it ran a 12.4)
Edited by PSI_GTSII
well only managed the one run due to stoopid gearshaft issues which caused a join with team breakdown along with paully and mitchy
then drove home playing find the gear 1st and 4th mostly but it was still a good night
top turnout for the club with some very respectable times as well hope everyone enjoyed themselves
haha hazards look siic
why did u do that :happy: ??
because Strich9 (kym) said that if he ran with them on again, he would bitch slap him
so michael did, but no slap :laugh:
yeah, heard about that gavin
i was walking past when i heard ya go 'finally, got first gear' then you took off
    • $53.35 and a double din Pioneer head unit that I have...
    • Put a camera facing your dashboard so you can film the gauges. Head out to a straight but of road, and filming it as you go from a stand still at wide open throttle to as fast as you can/feel comfortable doing. Then film the dash board as you for example accelerate like normal onto a freeway. This will give us an indicator from Speedo of your expectation of slow, and will give us the rpm reading too to see if it's shifting. (Auto still has tacho from memory)
    • Buy yourself the cooling system pressure tester. Being able to pump it up, and have a gauge on it, AND have a cold engine makes it much easier / practical to diagnose. Additionally as the engine isn't running, you can listen for pin hole leaks as well as watching if pressure drops away. In addition, you can pressurise and while doing so, watch all the little rubber hoses. Some fail very brittle, and will just leak, while others can end up very soft and bulge. While a bulging hose isn't necessarily leaking, one of those small ones starting to stretch / expand in a bad way is an indicator that you'll be looking to replace that one soon   Depending on if this is a project car, or you'll be dailying it in the summer months would alter how I'd be most comfortable with driving the car and how I'd replace. If you're planning to use it as a daily, with no backup, I'd pull the engine, and replace all the external oil/water lines in one big swoop. At the same time do the timing belt, water pump, tensioners etc. Do not open the engine at all. We just want to replace all the things that are inexpensive as a single item, but a PITA when they go. By doing the above, you've made the car from a bunch of age related issues more reliable. If it's a project, and you like swearing while trying to reach into dirty hard to reach places to replace a single hose that may or may not be the leaky one. Just replace the leaking/bad ones as they need it. If it's a project and you'd rather swear at the car once and enjoy it as much as possible, then refer to the process I mentioned in how I'd want to do it if it were a daily. However, the approaches above do come down to how much spare pocket change you have. Pulling the engine and dropping over a thousand dollars on parts, may not be practical for you. Oh, if engine outing, I'd replace as many silicon/rubber inlet joiners as possible too.
    • Yeah, they're pretty dumb though...ie; they'll throw a solenoid error if the solenoid is dead, shorted, wiring is open circuit, or even if the driver transistor has failed (they can't self-diagnose much, they can only test inputs/outputs)... but if you wanted to try, I believe it's this protocol....(uses a long pulse indicator with short pulse counter)...
    • Yeah I'll do what I can without taking off any major parts for now. If it becomes clear I won't get far with the engine in the car I'll have to think about the next steps. I am not too stuck on keeping everything 100% OEM, if there is better solutions, like converting most lines to braided with AN adapters, I'd rather do that than buy overpriced new "shit" parts.
