  • Replies 228
arkon, I'll bring a spare helmet if you get stuck.
Just not mine - we all know what happened last time! Only child dont share ..... not saying that any of you have nits but its my helmet - mine mine mine! :(
there were some pretty quick runs
Paul had some dramas - but maybe Dan can enlighten about that
D3vlish ran some quick times (Strich9's girlfriend) and so did Judged (rb26 r33 gts-t)
a quick count revealed about 30 skylines from SAUWA
